Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Power on when headphones are plugged in?
Old 12th July 2008, 11:26 AM   #1
SharpyWarpy is offline SharpyWarpy  United States
SharpyWarpy's Avatar
Default Power on when headphones are plugged in?
Hi, all. Can anyone explain or point me to a tutorial that shows a circuit that will power on a cmoy headphone amp when the headphones are plugged in? Thanks ahead of time.
Old 12th July 2008, 12:39 PM   #2
Originally posted by Juergen Knoop
some headphone sockets have build in switches
regards
Hmm, I've seen illustrations of phone jacks in the Mouser catalog with provision for disconnecting speakers when headphones are connected but none for power on/off.
Old 12th July 2008, 12:46 PM   #3
Juergen Knoop is offline Juergen Knoop  Germany
Juergen Knoop's Avatar
yes, my post was a little bit overhasty.
regards
Old 20th August 2008, 12:05 PM   #4
bump
Old 20th August 2008, 01:14 PM   #5
poynton is offline poynton  United Kingdom
poynton's Avatar
Usually, the ground (sleeve) of the connector is used to switch either side of the battery depending on how the phones are conected)
Finding a switched 2.5 or 3.5mm socket may be the problem rather than how to connect it.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 20th August 2008, 01:53 PM   #6
Andy
Thank you, poynton, for your reply.
The cmoy uses a virrual ground for the headphone return so using the jack sleeve isn't an option. The switched phone jacks available at Mouser, DigiKey, etc are designed to interrupt the output to speakers. I thought I could design a circuit to use that but, alas, all my attempts have been in vain. I tried a jfet/bipolar transistor combination with appropriate resistors but that didn't work. Promising, but didn't work, it just screwed up the sound. There was no DC offset, it just made it sound bad, which means I didn't get something right. So instead of pursuing that further I thought I'd see if anyone else had any ideas.
Old 20th August 2008, 03:27 PM   #7
Dan2 is offline Dan2  South Africa
what about a relay?
use a switched socket to drive the relay coil. (it will mean that u need voltage on all the time though)
but if u are close enough to plug the headphone in, surely it's nott too hard to flick a switch while you're there
Power on when headphones are plugged in?Hide this!Advertise here!
microphone + headphones + battery power truthbetold Parts 2 17th December 2008 11:41 AM
adding headphones on DOZ power amp tiagor Solid State 3 11th February 2004 07:07 PM
Low power tube amp for headphones trespasser_guy Tubes / Valves 112 28th January 2003 10:34 PM
