Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th July 2008, 01:28 AM   #1
Default Power supply question
Long ago after building the Pass A40 I played with the power supply some. The supply used 2 bridges and 4 10,000uf
caps to get a seprate + & - 32v supply per channel. I found that
the bass was tighter if I added another set of caps in parrell with
the first set. Well this is old hat and just as expected. Then I
removed the new set of caps and reconnected them across
the + & - power supply outlets. So I now had a 10,000 uf cap
from the + of the bridge to ground a 10,000uf cap from the -
of the bridge to ground and 20,000uf between the + and -
terminals. The added capacitence in this case didn't seem to
do a thing. I have always wondered why.
Old 7th July 2008, 04:10 AM   #2
Iain McNeill's Avatar
A 10,000uF cap from + to - is equal to a pair of 20,000uF caps from + to ground and from - to ground (caps in series)
Also, because you have two bridges - each bridge want to circulate its own ripple current. The added resistance of the other bridge reduces the effectiveness of the added +to- caps.
Amp power supply question theAnonymous1 Solid State 12 30th August 2008 05:06 AM
813 power supply question Richard Ellis Tubes / Valves 6 14th December 2007 03:41 AM
Another Power Supply Question soundbadger Tubes / Valves 12 10th October 2007 12:29 AM
Power supply question HugoR Tubes / Valves 9 9th November 2005 08:34 AM
Power supply Question Adam M. Chip Amps 10 4th May 2005 02:19 AM
Page generated in 0.07529 seconds (70.37% PHP - 29.63% MySQL) with 10 queries
