What might this mean for heat-sinks? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 1st July 2008, 03:51 PM   #11
wildburro audio
d to the g's Avatar
Originally posted by wakibaki
Since the amount of energy recovered on condensation is always the same, anything else would mean you could build a perpetual motion machine.
no. it's not. please see "Carnot engine". (seriously this is freshman thermo)
The energy recovered in the cycle can never exceed the energy in, but it can be made increasingly more efficient based on the temperature inside the cycle. If this lowers the boiling pt of water, it makes it more effiecient, as you don't have to heat the water to 100 C.
If you've got a point to make, make it on your own account instead of trying to ricochet off my contribution.
w
I was using your "point" as a reference of misunderstanding, which apparently continues blindly.
I would also like to see the actual data and experimental set-up. I am neither accepting or denying this claim, but find the claim unique and possibly a boon for such things as desalination.
Old 1st July 2008, 05:28 PM   #12
Banned
Originally posted by shallbehealed
no. it's not
If you have an argument to advance, make it in entirety.
Otherwise butt out...
Old 1st July 2008, 05:49 PM   #13
Speakerholic
Cal Weldon's Avatar
Not nice Waki. He gave you something to research.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st July 2008, 05:54 PM   #14
croat47 is offline croat47  United States
croat47's Avatar
Seriously, calm down. This is just a lilliputian version of a pin fin heatsink, no?
http://www.coolinnovations.com
http://www.coolinnovations.com/techn...s_articles.php
Not too hard to understand, and certainly not worth arguing about. Were we at a Gordon Conference and someone said that cold fusion had, indeed, been generated in their bath tub...maybe we could throw some flags. Forget the writer...look at the principles.
To measure this effect? Propose that you take a 12"x12" CSA vessel with a 0.25" thick bottom plate made of solid copper. Apply heat in your method of choice (propane, alcohol, jet fuel) to one side of the plate. Fill the vessel (other side of the plate) with a known volume of DI water. Measure the water temp until it hits boiling point at given pressure (Sea Level or Mt. Fuji). Calculate fuel expended and energy. Now, do the same with an application of said copper nano rods on the surface. (Height is negligible if they are truly "nano".)
Just a guess at an easy way to check this out.
If the energy expended is the same, your article is a hoax. If not, you have yourself a cool application and a heated (no pun intended) debate on an audio forum.
Peace.
Edited for clarity.
Aaron
Old 1st July 2008, 06:15 PM   #15
Speakerholic
Cal Weldon's Avatar
Waki's last post removed. Let's move on.
Old 1st July 2008, 06:23 PM   #16
jneutron's Avatar
They are talking about heat flux and the ability of heat to flow from the metal to the water. they characterize the efficiency by measuring the temp difference between the wall and the liquid (Tw-Tsat) and the measured heat flux.
They also reported that in subsequent tests using the same surface, there was degradation in the efficiency, which they called aging behaviour and attributed it to oxidation and the accumulation of impurities.
This statement within the article..""If you can boil water using 30 times less energy, that’s 30 times less energy you have to pay for,” he said. . ""....while in itself is accurate, implies that they required 30 times less energy to vaporize the water, and that is NOT what the origional scientific paper said.
Cheers, John
I hate all these smart gadgets..I refuse to buy things that are smarter than me. I've made a list of those things... Cabbage just made the list.
Old 1st July 2008, 08:16 PM   #17
SY's Avatar
Aaron, I don't follow your example here. Your example (a vessel) is a closed system (i.e., it's not a continuous stream of water flowing past), so the energy to boil the water is independent of the surface, it's a constant which just depends on the mass of water.
Now in a heatsink or similar application where there is a continuous flow of fresh "recipient" media, indeed increasing the surface area will increase the amount of energy dissipated per unit time for exactly the reasons that John cites. There's nothing mysterious about that nor any major breakthrough. If practical, it's just an evolutionary step, though nothing wrong with evolutionary steps!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 1st July 2008, 08:20 PM   #18
SY's Avatar
Ahh, an electrical analogy is in order. Aaron's vessel is a capacitance, the temperature difference is potential (voltage), and between them is a resistance comprising the thermal conductivity of the boundary medium and the interfacial thermal resistances. It's easy to see that the capacitor will charge to the full voltage regardless of the resistance- the rate at which it does so may be altered, though.
A flow system would be more analogous to a current sink than a capacitor, so it can be seen that the thermal resistances are critical to the total energy input per unit time.
FS: Heat sinks gengis Swap Meet 8 17th March 2006 02:27 AM
Heat Sinks serengetiplains Parts 3 3rd January 2006 07:41 AM
heat sinks D3 Pass Labs 9 29th December 2003 08:19 AM
Heat sinks - going the other way jackinnj Everything Else 9 27th April 2003 06:01 PM
Big Heat Sinks dshortt9 Parts 15 4th November 2002 08:36 PM
Copyright ©1999-2017 diyAudio
