Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th June 2008, 02:18 PM   #1
jackinnj's Avatar
Default New programming toy for "C", PICs and AVR's
Janneman had mentioned "Flowcode" from Matrix Multimedia http://www.matrixmultimedia.com./
a couple days ago on the Anatech thread dealing with the GPIB/HPIB -- there's a student/home license version for 39 pounds (there are distributors all over the world, I got mine from Micro Controller Pros in California http://www.microcontrollershop.com/ )
You just drag icons from the left onto your screen, fill in the values, compile to "C", then compile the hex code.
I purchased the software and a USB programmer to (to replace my PicStart Plus which has gone missing.)
Here's a screen shot from one of the tutorials:
Old 28th June 2008, 07:28 PM   #2
jcx is offline jcx  United States
automatic code generation is a popular academic activity, I haven't used any but I do look at a few of the free projects occasionally
http://ptolemy.berkeley.edu/ very flexible grapical system modeling software with the ability to produce C code from block diagram model graphs
http://www.scilab.org/ free matlab work-alike has a Simulink like block diagram simulator with code generation
http://www-rocq.inria.fr/scicos/
http://www-rocq.inria.fr/syndex/
used by a proprietary but cheap Microchip DsPIC based board, the "Flex"
http://www.evidence.eu.com/content/view/175/216/
these would be the "poor man's" version of the code generation tools in expensive commercial packages like National Instruments' or Simulink/Matlab which can "compile" complex signal processing and control block diagram to code or FPGA
as I said I just look, its hard to determine project maturity/usability without doing a few complete projects with a new tool/environment
I'd love to hear comments from people with recent experience
Old 2nd May 2009, 01:07 PM   #3
jackinnj's Avatar
Flwocode4 is coming out soon -- this month -- with a panel designer.
Old 2nd May 2009, 10:38 PM   #4
Johnloudb's Avatar
Jack,
I've been looking to get into PIC programming for some time. Is this a good way to start out? I've done programming in C years ago. And I kind of remember it, but I'll need to brush up. It's kind of like visual programming where you don't need to write much code?
Thanks!
My Website: Hyperacusis, Tinnitus, My Story
Old 3rd May 2009, 12:21 PM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Depends on how you define 'write code'. At some point, you need to tell the system what you want done. If you use flowcode with for example an LCD, you tell the system 'initialize LCD', then 'cursor to line x, position y', then 'print "Hello World"'. In ther right order .
If you use like a LED on say port B, bit 5, you need to say 'out 1->B5' to light the LED. And of course you need to be very clear in your head about the program structure and logic, no compiler can take that job off you.
Jan Didden
Old 3rd May 2009, 10:11 PM   #6
Johnloudb's Avatar
Thanks Jan,
I think I can handle that okay. I was mainly concerned about C syntax and debugging. I'm just not ready to write a bunch of lengthy C code. The only thing I've done similar to PIC was a very basic computer based ECG. Basically a high gain instrumentation amp, A/D converter connected to a parallel port, and a program written in C. Oh, and I did some IEEE488/GPIB programing of test equipment, using TestPoint programing environment. The instructions for TestPoint were a real pain ... back in 1996. If has decent instructions I should OK. Does it have good documentation?
Sounds good though!
Old 26th June 2009, 01:30 PM   #7
jackinnj's Avatar
Well, my Yamaha A-10 "Project" Integrated Amp ran into a roadblock -- the input switching consisted of dreadful CMOS Mux's -- and the push-button controls were driven by a set-reset counter. I wanted to use Silonex LDR's for the input switching but no matter how I configured them there wasn't enough juice to completely activate the LDR without causing problems with the SR FF.
I didn't want to rip up the entire input board --(it is inevitable, however.) I wrote this little routine in a couple of minutes with Flowcode -- note that you are only limited to 16 macro's in the free-ware version -- but the hobbyist version includes a USB Programmer and a 16F88. You can get around the macro-limit by writing your own "C" routines to substitute for macro's.
http://www.tech-diy.com/Receivers/Yamaha10/Flowcode.gif
Old 26th June 2009, 02:33 PM   #8
Banned
I had a look at this:
'The great advantage of Flowcode is that it allows those with little to no programming experience to create complex electronic systems in minutes.'
Hmm. Scary if true.
1. It's probably not true
2. If it is true, is it really desirable to have those with little to no programming experience creating complex electronic systems in minutes?
It's much better in the long term to stick to a mainstream programming language than delve into these proprietary 3GLs, which still have rules and syntax - they're just expressed differently. When you want to do something at a low functional level you will have to resort to regular tools (C, assembler which this thing generates).
If you want to program, this is how it works. You write a piece of code. You never write it again, just cut and paste. Pretty soon you can build most anything out of the bits you wrote already.
Only if your interest is truly superficial or perhaps if you have a great deal of undemanding code to generate should you go down this route. It might also be a good way of generating specimen C or assembler to modify if you are learning, much as it is possible to learn e.g. VB for Excel by generating Macros with the mouse and then examining them to see how the code works.
PIC etc. programming is not so difficult that it needs to be made easy.
w
$0.02
Old 26th June 2009, 03:05 PM   #9
jackinnj's Avatar
When I took organic chemistry, the instructions at the beginning of each test went something like this: Using carbon, nitrogen, hydrogen and oxygen, heat and pressure synthesize the following molecule: (It wasn't quite that bad, but you were working with very basic building blocks.) I took organic so long ago Kekule was still around.
Nowadays, young men and women going into engineering have never soldered anything and most have never used a hand-held radio.
I generally concur and no one wants to use code that cant' be validated...and the temptation is that your code will look something like an early windows operating system! But I started programming in the punch-card era.
Old 13th July 2009, 06:40 PM   #10
jackinnj's Avatar
Some of the new toys in Flowcode4 -- probably am too old to figure out how many of them work -- GPS, Webserver, TCP_IP etc.
PICS: "Optimos" 140W Monoblock Amps! Rarkov Solid State 50 28th April 2011 02:54 PM
pics of finished "industrial gainclone" cowanrg Chip Amps 0 28th June 2005 07:24 AM
Finally completed "Delta" enclosure (pics) David Gatti Multi-Way 35 12th February 2005 02:30 AM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Page generated in 0.13644 seconds (84.51% PHP - 15.49% MySQL) with 11 queries
