| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have some ideas as to improve the look of DIY PCBs.
Personally I am not fond of the look of those bare boards and got started to brainstorm some ideas as to make them a bit more professional... After the PCB has been etched and washed I would suggest covering all the solder pads with tiny dots of masking-tape and then to spraypaint the top and bottom with "high temprature" aerosol paint (red, blue or even white!). High temp paint is preffered as it wont muck up when you solder - 600 degree celcuis proof. After paint has dried you can then mark the component positions with a permanent, fine tip marker and possibly a stencil of some kind. Lastly mark all places with component ID numbers. Peel off the tiny pad masks and assemble the thing! D Any ideas to add? |
#2 |
Hi Dewald, skip the stickers, I spray my boards often with plain aerosol cans.... it is easy enough to scratch the copper bits clean where you need to solder... I just use a little flat screwdriver...
My process is to etch the board then tin it useing large amounts of flux and as little solder as possible, afterwards the flux is washed of with alcohol or acetone, and the board given a good wash with dishwashing soap under hot water... this is to remove oils. Also the flux tends to eat into the spray paint, and will stay in drill holes even after washing, only to seep into your paint... so, leave drilling till last. Once the boards are dry, handle them with gloves or kitchen towels to keep your finger oils off... also wash your hands for those unintentional touches... Now you are ready to spray... After spraying I put my boards in an unused fridge to keep dust and insects off it untill it is dry... A cake tin or icecream tub could also be used I guess, with a few small holes to vent the fumes... Many thin coats is better than one thick one.. Darker colours work best as they don't show dirty fingerprints and discouloration from soldering iron slips. |
| Need ideas to make heat sink with this plate | space2000 | Solid State | 11 | 1st August 2008 07:07 AM |
| Clear acrylic speakers - any ideas? (Also, how should I make B3s open baffles?) | Spasticteapot | Full Range | 17 | 22nd October 2006 04:19 PM |
| Ideas on how to make front baffle removable? | tf1216 | Multi-Way | 11 | 3rd April 2006 04:53 PM |
| profesional tools | Ipanema | Everything Else | 0 | 16th June 2005 01:30 AM |
| Page generated in 0.07781 seconds (73.40% PHP - 26.60% MySQL) with 10 queries |
