| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I made a set of these today using scrap oak and .9999 silver wire. They came out really nice ( way better than they look in the pictures) but I havn't had a chance to hear them yet. It took about 20 mins to make the two of them. I will do them over again real pretty now that I see they work.
See the originals here. http://www.xs4all.nl/~rabruil/bullet.html
My "cult-like" following is accepting applications. |
#2 |
both
#3 |
You should probably call those "DIY 47 Labs" rather than "DIY Eichmans", because the Eichmans themselves appear to be knockoffs of the 47 Labs Otakit RCA cables.
jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com |
#4 |
Tom
What a great idea! I've been using the originals (copper) for a while and really like them a lot but there is no reason yours wouldn't be better. How is the center pin made? cheers peter |
#5 |
Link to the Otakit:
http://www.47labs.co.jp/4708.html 47 Labs utilizes the conductors of the cable for the conductive part of their two-part RCA connector. The 47 Labs Otakit is a natural for solid-core cable, and sounds substantially better than the Eichman. hth, jonathan carr
#6 |
Johnathan
I was not aware of the 47 labs connector. Now that I've seen it, I will try to copy that. peter The center pin is just a silver wire, bent at the back to keep it snug and bent slightly at the front to make contact at only one point. I will also try to remove some of the contact area on the return wire to resemble the eichman a little closer. I'm really kicking myself for not doing this earlier.
#7 |
Version 2.0
It's like a hybrid between the 47 labs and the Eichmann. I am working on doing away with the center pin but I'm not quite there yet. It sounds really nice. At first listen a layer of glare on the letters S, F, and T has been removed. Doing one at a time and listening made me want to do the other one right away.
#8 |
complete
#9 |
installed
#10 |
diyAudio Senior Member
Nice work. If you like what you're hearing, here's a source for even more inspiration: AUDIO CONSULTING Personally I had good results with stripping/skinning caps, you may want to try that too. Cheers,
Frank |
| Eichman bullet RCA's | BobM | Parts | 27 | 28th August 2009 10:13 AM |
| Deep Cryogenically Treated Eichmann Bullet Plugs | mozfet | Swap Meet | 0 | 26th July 2003 10:45 AM |
| Page generated in 0.11220 seconds (82.55% PHP - 17.45% MySQL) with 11 queries |
