Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th June 2008, 12:42 PM   #1
bulgin is offline bulgin  South Africa
Default Do you like it straight, or amplified?
Hello All
Music from your computer, I'm writing about. I have an arrangement connected to my computer which already gives very nice sound. I use an inexpensive subwoofer (subwoofer turned down completely) and I use only the amp inside to amplify sound from my computer. Instead of using computer speakers, I have connected a pair of mini monitors to the subwoofer (in the place of the speakers which came with it.
Which makes things even better, is that the subwoofer came with a wired remote with which I can control volume and switch it on or off.
I recently bought a little Scott integrated (40W/ch) which I'd like to use in the place of the subwoofer's amp.
I will probably have to give up the convenience of the wired remote, unless I can find a way to connect that to the Scott amp.
Do you have similar arrangements (using an amp and better speakers) connected to your computer?
Cheers
bulgin
Old 20th June 2008, 04:18 AM   #2
Iain McNeill's Avatar
to be honest, I can't get enough volts and amps out of my PC soundcard so I'm 100% amplified and proud (tri-amped!.
Many cheap soundcards have really poor performance (distortion, noise, etc) It takes a lot of careful engineering to get close to 96dB dynamic range out of a 16-bit CD transport, but there are some gems out there. Due diligence.....
Old 20th June 2008, 06:15 AM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
have not done it in years, but yes uncle B, it sounds pretty good compared to pc speakers..
Old 26th June 2008, 10:58 PM   #4
Default Do you like it straight...
It's a mess but it's up and running.
From the Scott's AUX to an Edirol UA-1EX outboard soundcard and with a pair of bookshelf mini monitors things are sounding rather dandy. Only 40W/ch but this is ample for computer sound.
bulgin
5.1 CPU output to amplified hi-fi speakers burp105 Chip Amps 1 20th January 2006 01:35 AM
Infinity BU1 amplified subwoofer. problems. pat allen Solid State 0 30th December 2004 02:42 PM
My amplified sound cube soundNERD Chip Amps 12 16th August 2004 02:07 AM
amplified tv antenna karma Everything Else 2 23rd July 2004 01:48 AM
Amplified speakers Stefano Pass Labs 11 11th June 2003 06:08 PM
Page generated in 0.07508 seconds (72.34% PHP - 27.66% MySQL) with 11 queries
