| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Audio Junkie
I am repairing my HP651B Oscillator. It is getting to that age where the caps are going bad.
The output is fed through a 1200uf 10VNP cap. which i assume the VNP stands for Volts, Non Polarized. My Fluke 189 shows the value of the cap to be good but i suspect its age is causing some problems. I get some DC offset occasionally. So two questions. where to get a BIG NP cap as such. and two, what factors should i look for in a NP cap. I would like to replace it with an equivalent or better part. Could i use a couple of caps back to back to form the NP??? and what issues would i face as such? |
#2 |
Hello ZeroCool, Your best bet for large value NP electrolytics is probably someone like Madisound, Parts Express, Zalytron, etc. Look for companies that specialize in supplying DIY speaker builders. I took a quick look at Madisound and the had some from Bennic that went to 1000 uF. This one possibility. If you are really trying for exact value, parallel a 200uF with it.
You can also put two conventional electrolytics back to back to get the same effect. Issues I can think of quickly are space contstraints. Peace, Dave |
#3 |
Audio Junkie
I have plenty of space in this unit. so thats not an issue. Just want to make sure i can repair it as best as possible. I use this thing every day!
#4 |
I can understand. From what I saw with a little quick looking around, Madisound seemed to have the largest available NP Electrolytic at 1000uF. Parts Express stopped at 500uF and Zalytron didn't appear to carry NP Electro's at all. I would say do a price comparison between Madisound and Parts Express, and also compare for quality where possible. Then buy the ones you need to put a few in parallel to get the 1200uF value you need. The caps for the crossovers that were listed at both sites are rated for 100v, so they should have no problem in your application.
Peace, Dave P.S. Please report back on your success! |
#5 |
Audio Junkie
When putting two caps in series back to back to form a Bi-Polar/Non polar whatever you want to call it. Is the capacitance still added? or will the value be that of each individual capacitor?
IE: if i put two 600uf caps together in series. do i have 1200uf or 600uf?? Connecting them + to - i would assume it would be 1200uf. But because they are back to back, is it then the same??? And, does it matter if i connect them +to+ or -to-??? Zc |
#6 |
Hello Zero Cool, I am having a bit of a mental block in regards to what the capacitance value will be, I think it will stay the same as the value of one of the caps, but to make a Bi-polar cap, you would hook the positive leads of both caps together, with the caps in series. Then the negative terminals become the connections to the rest of the circuit.
If you want a larger value of capacitance, you would hook the caps in parallel. If you want a smaller value of capacitance, but a higher voltage capability, you would hook the caps in series. Caps in parallel are additive, caps in series are subtractive. But series wiring of caps increases the voltage capability. The subtraction only happens if you hook positive to negative. If you do this to increase the voltage, use caps that are rated at the same voltage and capacitance value, and put large value resistors in parallel with each cap. The resistors will help balance the load between the two (or more) caps. Hope this helps. Peace, Dave |
#8 |
nonpolar (aka Bi-polar) Al electros measure lower distortion than back to back series normal polar electrolytics
higher V rating performs better too if blocking Volts of DC then series nonpolar Al electros were the best high value type in Bateman's tests search digikey - panasonic SU Bi-polar 2200uF 25V in stock http://search.digikey.com/scripts/Dk...?name=P1185-ND |
#9 |
Audio Junkie
I wonder if a larger value in this instance would hurt performance any??? The Osc goes quite low in Freq. less then 1 hz i think so thats why they used such a large NP in the first place. I wonder if using a bigger NP will hurt any??
#10 |
NP has recommended the ELNA "Silk" caps for the F4 -- so I would suspect that RFS35V102MK8 (604-1069-ND from DK's website (1000u/35V) would fit the bill).
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Oscons as decoupling caps in output stage | Ruach | Digital Source | 6 | 24th August 2005 04:31 PM |
| AD825 output stage:What bypass caps? | filholder | Digital Source | 3 | 16th April 2005 06:15 PM |
| Page generated in 0.10122 seconds (80.73% PHP - 19.27% MySQL) with 10 queries |
