Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th March 2003, 03:00 AM   #1
SY's Avatar
Default AutoCad to bmp
OK, I'll admit to being a total ignoramus when it comes to this computer stuff, so if you have ideas to help me, use nice, simple words, maybe at a 10-year-old level.
I've been struggling with ways to get schematics up on the BB and turned to AutoCad. I can draw stuff in AutoCad and make it more or less plot OK. However, when I export a drawing to .bmp format, the .bmp file shows a reasonable size (a couple hundred kbyte) but when I open the .bmp with another program like Paint or Fireworks, it displays blank. What am I doing wrong?
FWIW, I'm using (don't laugh) AC97, Windows 95.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 13th March 2003, 03:12 AM   #2
JBL is offline JBL  Canada
JBL's Avatar
Send a message via ICQ to JBL
After pressing ok for the export file you must selct wath you want to export in the drawing.
You thus need to drag your mouse around the entire drawing.
And only then press enter.
Jonathan Blanchard (J.Bl.)
---Nothing is impossible---
Old 13th March 2003, 03:12 AM   #3
jcarr is offline jcarr  United States
SY: This may not be a direct solution, but another way is to expand your AutoCad drawing on the screen as large as possible, then do a PrintScreen. Now open the Paint application, and do a Paste. Trim the edges (I use Cut - NewFile - Paste), and you should have a presentable BMP of your drawing. The filesize of the bmp will be large, but zipping it will bring the size way down, and you should be able to post the zip to DiyAudio with no problem. Use a graphics file format conversion application if you want a GIF.
Also, I suggest that you consider something like SIMetrix for drawing your schematics.
hope this helps, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 13th March 2003, 05:04 AM   #4
SY's Avatar
Thanks, guys! With your help, I got it.
I use Fireworks to convert and compress; that's an almost foolproof program, thus safe in my hands.
Old 17th March 2003, 02:11 AM   #5
frugal-phile(tm)
planet10's Avatar
This is essentially the technique i use for getting my drawings onto the web. Set the screen image to correspond to the right size, take a snap-shot (OS Xs postscript display does a great job), then open in Photoshop (you could just as easily use GraphicConverter or PhotoShop Elements* or any number of other raster editors) to crop it and save it out as the smallest possible gif.
For AutoCad drawings, i import them into VectorWorks and clean them up 1st)
*(if anyone is looking for a good raster editor this has to be the best value in raster editor for either Mac or PC)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th March 2003, 02:57 AM   #6
SY's Avatar
OK, I know I'm gonna sound REALLY stupid, but I assume that to do a PrintScreen means to hit the PrintScreen key? If so, when I did that, exactly nothing happened. I hope I'm not like the driving student who, when instructed to parallel park, put the automatic transmission in "Park," then complained because the car wasn't parking.
Selecting before exporting worked OK, though there was a major resolution loss going to a bmp. The gif looked identical (Fireworks exports like a sane program should, the whole image), and was delightfully compact (like 5K or something). My first attempt is over at the "math" thread. It looks a little fuzzy compared to the original AutoCad image for sure.
Old 17th March 2003, 03:24 AM   #7
frugal-phile(tm)
planet10's Avatar
Originally posted by SY
[B]OK, I know I'm gonna sound REALLY stupid, but I assume that to do a PrintScreen means to hit the PrintScreen key? If so, when I did that, exactly nothing happened.
On a PeeCee you may require a screen capture program (i don't do Windows so i'm not sure)
On a Mac command-shift-3 captures the entire screen(s), or command-shift-4 gives you a set of crosshairs so that you can select what you would like to capture.
dave
Old 17th March 2003, 03:41 AM   #8
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Hey SY,
I had the same problem. As a former Mac owner it also seemed to me that nthing happened when I hit the print screen key.
On the Mac a screen capture makes a cute "shutter snap sound"
On the PC it just noislessly captures the image, then when you select "paste" in the "edit" menu, pastes it into the current file that is active.
So , sorry p10, PC's actually do this rather well.
Mark-an ex mac owner who wishes those Autodesks jerks hadn't canceled unix Autocad just when the MAC OSX came along (which could have used the unix version with a tad of tweaking)
Old 17th March 2003, 03:49 AM   #9
SY's Avatar
I'm grateful to all the geeks bearing gifts. AutoCad is monstrously powerful (Drafting Dan, for other Heinlein fans) but user-hostile.
Old 17th March 2003, 04:36 PM   #10
i've stopped being surprised at the places i find heinlein fans.
by the way...another option for turning an autocad drawing into an image file is to 'plot to file' using the eps format. then convert the eps into whatever format you like, using your favorite image software. i believe this way you can preserve line weights, if you have them defined that is.
you could also use 'psout', or 'export' using eps format...but i'm not sure if it lets you 'window' the area you want to export.
in that case you'd have to crop the image when you go to convert it to bmp/gif/jpg.
/andrew - sometimes dreams in cad. it's scary when that happens.
Ariel 6c AutoCAD drawings johngalt47 Multi-Way 16 29th September 2008 10:53 PM
AutoCAD of tube Packages? Zero Cool Tubes / Valves 4 31st August 2008 06:15 PM
Autocad help DrWoofer.com Subwoofers 12 1st August 2007 07:30 PM
Autocad 3d Model of any woofer driver? ANY? ssabripo Multi-Way 7 4th January 2006 01:04 PM
Autocad for 11-sided horn design? terminalcity Multi-Way 10 27th June 2005 04:35 AM
Page generated in 0.11455 seconds (81.07% PHP - 18.93% MySQL) with 10 queries
