Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
How to measure JLH Class A with a Scope
Old 16th June 2008, 05:47 PM   #61
chris ma is offline chris ma  Canada
chris ma's Avatar
Hello there,
The place have moved. Took me awhile to find it again.
Just got them now. But they are only 2W 5% for 4 each of 0.47
and 0.33 and 0.22
I did not want the white rectangle ones. They have 5W but not the exactly the same values as you have specified. I also have the 10k log dual gang now. How do one wire this pot up? It has 6 contacts. From CD audio out to pot and from pot to the RCA input of power amp. One channel at a time as my power amps are mono blocks.
Birds eye view of the 10k log pot
The Butcher
Old 16th June 2008, 05:53 PM   #62
Mooly's Avatar
Hi Chris,
All pots are basically the same. Hope this makes sense.
Old 16th June 2008, 06:09 PM   #63
Mooly's Avatar
The wiper is always the middle leg. Ground one side as shown and apply the input between the other leg and ground. The signal is always taken from the wiper and ground. If you got the two end connections reversed the pot would work back to front !
This shows just one channel-- just copy it for the other one.
Old 16th June 2008, 06:30 PM   #64
chris ma's Avatar
Hey Karl,
That's the one I got shown in your pic. Thanks.
The Butcher
Old 18th June 2008, 04:53 PM   #65
chris ma's Avatar
The sharing of the current is fixed after I replaced the 2N3055 with the Mj21194G that came through the post from On-semi.
They are not perfect but they measusred at 80mV and 71mV for Q2a/Q2 and 83mV and 69mV for Q1a/Q1
So the PSU ripple seems fine. Next thing to try now is to wire up the pot and connect the CD player to the amp and play with the scope to see how well the JLH reproduce the sine wave and square wave. Is that the right approach? I have warmed up the amp for an hour or so after putting in the new output transistors and the DC offset and Iq is very stable. With the above voltages across the emitter resistors what Iq current I have set the amp at ?
80 + 71 = 151mV ; that would be 1.5A Iq is this right?
The Butcher
Old 18th June 2008, 05:19 PM   #66
Mooly's Avatar
Hello Chris,
Thats good, sounds like they are much better matched gain wise.
Yes 80 mv across 0.1 ohm is 0.8 amp, and 71 mv is 0.71 amp. Just add them together as you have = 1.51 amps.
I am not sure what the original recommendation was now for the 1969 version. And yours is the "high power version" with multiple outputs. It was all of that though ! 1.6 Amps I seem to remember.
A lot depends on your PSU and the thermal management you have.
Wire the pot up next, just make sure you get the earth at the correct end as shown in the previous picture.
Regards Karl
Old 19th June 2008, 03:12 AM   #67
chris ma's Avatar
Well some scary moments
After I wired up the pot and played with the scope and amp for a little while, everything seems fine and then I unclipped the clip from the RCA input of the amp and I made some sparks after that the scope was showing the amp was acting strange with some strange looking sine waves comes and goes with no input from the CD player(disconnected); also the Iq current went up from 70mV to 200mV so I shut off the amp immediately wait for 5 minutes restart everything and it seems normal again.
Now evrything cool down a bit ,,, so am I
Took couple of pictures
Scope settings for both channels
Sec/Div set at 0.2ms
Volts/Div set at 0.5V
Top trace is from CD player thru the volume pot to the JLH and using 1X probe connect at the speaker outputs.
Bottom trace is direct from the CD player to the scope using RCA interconnect for compare purpose.
The CD is playing a 1Khz square wave.
Something is not right here. My camera seems to over expose but I can not use flash to take the pics.
Hope you can make it out of what the traces are telling
The Butcher
Old 19th June 2008, 03:14 AM   #68
chris ma's Avatar
Here is the second pic with the lights turn off in the room. But it is still over exposed.
P.S.
Karl, thank you for your input.. Without your encouragement I would not have gone this far. Although I have no idea what the scope is telling me at the moment some how I feel that I have accomplished something and it is a very good feeling. Thanks again. Owe you a pint!
The Butcher
Old 19th June 2008, 07:13 AM   #69
Mooly's Avatar
Hello Chris,
"Sparks in the dark" scary stuff !
First question, did you have speakers connected while you are taking the reading.
This is where it gets really difficult without it all in front of you.
Try the measurement again, NO load attached , with just one channel of 'scope connected direct to the speaker output. We know the output from the CD is OK so lets keep it simple.
See if the "overshoot" on the waveform varies at different gain settings of the volume pot. Try from a few 100 mv output up to just below where the amp begins to clip which will be a value just a bit below the supply rail voltage. Make sure you connect your probe ground to the actual speaker negative point, not some point in the PSU.
Old 19th June 2008, 03:22 PM   #70
chris ma's Avatar
There was no load attached. The only thing connected to the speaker binding posts were the DC offset checking multimeter and the probe of the scope connected correctly.
The wave form as in the pics looked the same with different volume setting. But when I made a mistake of passing the amp with very high volume the trace moved right of the screen and the amp started to make faint mechanical hum/buzz noise and I dared not to overload it for more than 2 seconds.
The Butcher
How to measure JLH Class A with a ScopeHide this!Advertise here!
Can I use a scope to measure powerline noise? Saurav Equipment & Tools 31 5th January 2017 04:32 AM
Measure the output of a bridged class D ocool_15 Class D 5 20th April 2008 07:12 PM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 09:59 PM
Want to measure ÁV on the scope: should I buy a new one or build a low noise preamp? Bricolo Parts 43 1st November 2005 08:41 AM
Can I look for (or even measure) distorsion on an amp with a dual scope? Bricolo Parts 17 17th September 2003 02:06 PM
Copyright ©1999-2017 diyAudio
