| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
What are the main changes associated with lead-free hand assembly cosmetics?
#2 |
Have you tried using lead free solder yet? It is HORRIBLE. You also need higher temperatures...
This RoHs is VERY wierd though but I agree with most of it: 'lead' free is a euthamisim, it is not just about lead content. It has taken us the best part of 2 years to get to lead free on our products.... products that rely on heavy LEAD acid batteries... Andy |
#3 |
Lead-free solders flow a little slower than 63/37 using the same activation levels for the fluxes.
The contact angles are slightly larger and feathering out of the solder is therefore less pronounced. The solder joints tend to be less reflective than 63/37 solder. Some re-training is required prior to a full transition to lead-free is done. In some cases certain shrinkage effects as described in Section 5 of the IPC-STD-610D occur. The IPC-610 classifies these as soldering anomalies and not necessarily defects. As mentioned on page 5-22 of the above document, it is not a defect for Class 1, 2 and 3 if the tear bottom is visible and the shrink hole does not contact the lead, land or barrel wall. See the photos below for examples taken from the Kester laboratory. What is the best soldering tip temperature for lead-free SAC and SnCu? The temperature of the tip or contact temperature is very important to ease the lead-free handsoldering operation. When using 63/37 solders temperatures as low as 650°:F have been used but with lead-free 700-800°:F is best. The higher temperature does compensate for the slower wetting exhibited with these lead-free alloys. Above 800°:F issues of board and component damage may arise; at lower temperatures cold solder joints and flagging are the normal complaints. Higher temperatures and longer contacts with the parts to be soldered may also increase the intermetallic bond layer. So avoiding prolonged contact and repeated rework is not recommended. The above diagram shows what happens as the bond layer increases in thickness a higher risk of embrittlement occurs. The risk of de-wetting also increases with higher temperatures. I think it will help you out.
http://swpc.co.il/ |
| want dead counterpoint SA100 SA-100 in good cosmetics | jlw | Tubes / Valves | 0 | 4th October 2007 08:52 PM |
| cone cosmetics | el`Ol | Full Range | 4 | 27th June 2005 03:21 PM |
| A little hand 4 amp_man | Polimorph | Solid State | 2 | 15th June 2004 01:18 AM |
| Second hand oscilloscopes in the UK | trwh | Equipment & Tools | 10 | 17th November 2003 05:57 PM |
| Page generated in 0.07620 seconds (71.75% PHP - 28.25% MySQL) with 10 queries |
