Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 19th May 2008, 04:50 AM   #11
Sh1mmy is offline Sh1mmy  Australia
It is interesting about the swappable opamps, and i would be curious about it. however I'm not really sure if i would change them if i got the card, especially if it did the job well enough. I would still be curious about changing them though.
They do have/had a few cards that had interchangeable opamps, and they all followed the same pattern, with the front channel have a different/better opamp than any other.
So it seems that without going for a dac or something, a card like an Auzentech might be best for me especially value and feature wise.
There are a few cards i have looked at made by different people and use the same/similar processor and they are virtually identical.
Going by your last paragraph, (if i understood it right), the circuitry, power supply and interference play a bigger par in quality control?
I do agree with the interference, and have seen threads where people have made shields for their cards and reported an difference in sound, in particular noise, general quality and warmth, which is what i like to hear.
In a way, I can't quite grasp the idea of caps making much of a difference when using an amp to power the speakers. Don't know if its just me or something i don't understand or what.
Had a another look around, and found the Asus Xonar D2/X and DX, i could lash out a bit more $$ (about $70 i think) and grab one, these come with a shield (although only on one side), and offer higher SNR and from a small review good quality, this would be a good bundle as it would also support games better too.
http://www.asus.com/products.aspx?mo...=144&l3=0&l4=0
http://www.asus.com/products.aspx?mo...=150&l3=0&l4=0
http://www.asus.com/products.aspx?l1...15&modelmenu=1
I think the only difference between the D2 and D2X is just the PCI-E 1x and normal PCI. If i was to get one, would it be a more wiser idea to go for the normal PCI model, as it has less in the circuitry (some adaptor chip for the processor to get it to work on PCI-E 1x) and would have the option to mount it further away from my video card (ATI 3870)?
Thanks.
Old 19th May 2008, 05:13 AM   #12
49 - for the 17th time
c2cthomas's Avatar
Good review of the DX2 card here: http://www.elitebastards.com/cms/ind...=496&Itemid=27
Looks to be a nice audio card BUT it uses Windoz VISTA - and do you really want to go there?
Also looks to be a good game card running under Vista - and I believe that a gaming card was one of your desires.
DIY audio can be expensive – but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 19th May 2008, 05:35 AM   #13
Brett's Avatar
PCI suggestion would be the MAudio 2496 or 24192 the latter of which I picked up on sleazebay for $A150 to my door NIB.
Old 19th May 2008, 06:32 AM   #14
BudP is offline BudP  United States
BudP's Avatar
Sh1mmy
Here is some hard comparative testing done by none other than John Atwood and his Audio Precision. Backs up Brett's intuitive choice....
http://www.clarisonus.com/Research%2...oundCards.html
Bud
Old 19th May 2008, 12:25 PM   #15
There are drivers that allow it to be used in XP, I think.
it does seem like a pretty good card, and seems like a mixture of all the things i wanted.
M-Audio 2496, theres one of these on ebay right now for $90+$15 S/H. Still got a couple of days left, no bids on it yet either.
Originally posted by BudP
Sh1mmy
Bud
Thanks, taking a gander at it now.
Old 19th May 2008, 04:55 PM   #16
cuibono is offline cuibono  United States
cuibono's Avatar
BudP, thanks for the site. Its always interesting when someone actually does some good comparative measurements.
This is another site, although with older soundcards. The RMAA (rightmark audio) forum might be another decent place to look up actual users specs for their soundcards. I never believe manufacturer's published specs, they're usually wrong, and they don't show any graphs either. On the other hand, I don't know if there is a strong correlation between specs and sound anyways. The gaming cards sure like to boast about S/N.
WRT the Asus card, I wouldn't buy any of them, they look like a fledgling manufacturer. Driver updates are critical, and I read they don't keep up on them, which is typical for companies that make soundcards as a side project.
WRT PCI versus PCIe, get whichever works easier in your computer. Less complicated = less hassles. Similarly, get a card that is meant for your OS, not one which had the drivers written as an afterthought...
Old 20th May 2008, 04:43 AM   #17
Yeah, they do boast a bit about a few things, and you do have a point about specs not meaning sound quality.
As much as I know, they have recently released a new set of drivers, and they seem pretty good, (only by what ive read though, dont know about the truth).
While I would prefer to get a card from a more dedicated brand, but the Asus card seems to have a mixture of what I'd like to have.
From what I've read, they drivers are pretty good for both XP and Vista, but again, I'm not sure about the truth there either.
Old 21st May 2008, 12:35 PM   #18
sousmielie's Avatar
hi,
If you want, you can build your own USB soundcard... Check out TI's PCM2704, PCM2705, PCM2706, PCM2707. I built one with the PCM2707 about 2 days ago and it is very good sounding. I have PCB layouts if interessted...
No drivers needed for WinXP or VISTA, Plug&Play
Old 22nd May 2008, 04:33 PM   #19
Thanks for that.
Old 28th May 2008, 02:09 PM   #20
Have looked around a bit more and have found a DAC that may be a bit more suitable/usable for me.
Zhaolu D2.5
(http://www.coemaudio.com.au/Sources/DACs/177/)
What are peoples opinion on these?
I've done a couple of searches, google didn't seem to reveal much and the forum was mainly just modding it.
Also, theres a couple of others i was looking at also, same price also.
Lite DAC-AH
http://www.coemaudio.com.au/Sources/DACs/184/)
KingRex UD-01
http://www.coemaudio.com.au/Sources/DACs/195/
Thanks.
Anyone tried those cheap usb sound cards? Westerp Digital Source 1 5th May 2009 09:47 PM
Sound cards for use with laptop jamikl Digital Source 16 10th December 2007 08:37 PM
General question about Sound Cards davidlzimmer Digital Source 4 24th March 2007 03:26 AM
PC Sound Cards guitargully Solid State 2 26th October 2004 08:02 AM
Copyright ©1999-2013 diyAudio
