Flush mounting speakers: the whole story - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th May 2008, 03:56 PM   #11
Default parts list for making a square flange flush mount
Tools and parts
4 3/4 screws (or however many hold the driver to the wood.)
8 1/16 in washers
1/8 thick foam gasket tape
1/2 in MDF -- size depends on driver
Plunge router
Router table if available
Circle jig (or your preferred method of making speaker cutout)
Jig saw/ table saw
1/4 in straight cut router bit
3/8 in flush trim router bit
Router base attachment with 3/8 in guide
Drill
As you can see there are more parts than we've talked about so far.
I noticed something just while making this list: I thought it said
"3/8 in guide drill" rather than 3/8 in guide. I've been looking for a "guide drill." My bad.
Some issues that haven't been touched on yet are how to register
the jig on the baffle. The screw holes for the driver can't be used because the pattern is too big.
Also is there a way to avoid using MDF and get the right thickness?
Perhaps gluing up some masonite? I worked with MDF once. I don't care to do it again.
Old 10th May 2008, 04:31 PM   #12
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: Re: Flush mounting speakers: the whole story
Originally posted by OzMikeH
The Fostex 206 and 207 are diabolical. what were they thinking? Has anyone ever flushmounted one of those? a good seller would be a machined wooden ring to cover that wonky frame.
Quite possibly minimum steel for the strength required. We have this pattern in the CNC, wouldn't be hard to turn that into a product. Take a bit of fiddling to turn it from a rebate into a cover plate, but that is something similar to something i was just plotting for finishing up a set if FH.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th May 2008, 05:18 PM   #13
MJL21193's Avatar
Originally posted by loninappleton
I can see where I'll get a heacahe flipping around between images
back and forth.
This illustration depicts the first step from the print article.
The author some other details like spacing out the speaker from the
template with 2 each 3/8 washers at each screw point to avoid damage to the driver.
Sorry for breaking in here and offering a perfectly reasonable and effective method (I've actually did this before). All this and with pictures too, that will give you a headache.
The driver doesn't get damaged as the bearing of the follower bit only touches it, not the cutter. As always, it'll pay off to be careful and precise in the set up.
Old 10th May 2008, 05:39 PM   #14
And put those goggles on too. :-)
I just want to have all the info together in some reasonable form.
No criticism intended of your illustrations.
Also did not spell check very well. My bad.
My headaches are just having to deal with screens rather than some printed source. As noted, I have a print source but it just isn't clear. I'm not trying to be thick. But part of the technique from the print piece sounds like "insert flap "A" and throw it away"--
and that from an essay by Robert Benchley.
There is a video out by Gary Rugowski from Fine Woodworking on
router technique. That doesn't have this procedure in it either.
It's nuts.
If someone has a how-to in book form I'll get one.
That's why I'm hoping that a photo how to will appear from someone. The truth is, I don't even own a real router yet.
Old 11th May 2008, 10:11 PM   #15
Default continuing the Buike method
To continue the discussion of the Buike method mentioned in
the early part of this thread in #11:
The illustrations at post #7 give the first two steps in this method:
Use 1/2 in stock of MDF or other.
Mount the driver face down with the driver hole plug removed
The driver is spaced using the washers in sets of two.
Shape the first piece using the 3/8 in flush trim bit around the
edge of the square flange.
Mount the first piece to a second larger blank to make the
template. Drill a hole at the edge 3/8 in and make a cutout
with the 3/8 flush trim bit. This gives a cutout 3/8 larger than
the first piece. this has to be perfect and smooth.
The next step is to use a 1/4 in. straight bit with a 3/8 in bushing
on the bit. The bushing is not in the parts list which I will correct.
Where it says 'router base attachment with 3/8 guide' means the bushing setup.
The text describes shrinking the pattern down to size using a 1/4 in straight cutting bit and a 3/8 in bushing to cut out the middle section which gives the original pattern plus 1/8 in. This would be the third blank used.
Buike gives the use of the 1/8 foam tape here. The foam tape is to insure the cutout is centered. The foam tape is lined around the
pattern.
This is real close to what pinkmouse describes as it all comes together and MJL21193's diagrams as well.
The final result should be to use the 1/4 bit with 3/8 bushing
to hog out the shape on the baffle?
I'd still like to see it done.
The last part of Buike says to fasten the pattern with air nails or
two sided tape. There has to be a way to register the pattern
better than that without damaging the baffle.
That's all I have for now.
I hope there's some improvements from the regular router users here.
Old 12th May 2008, 04:48 AM   #16
Pano is offline Pano  United States
Pano's Avatar
BTW: nice circle jig with the threaded rods. I'll be making one of those.
perhaps a bit of steel angle instead of the wood to stop the hole from flogging out?
Thanks Mike. Yeah, the metal centerpiece is a good idea. I may do that too. But really, I have had zero problems with the wood. There just isn't any real wear.
I like John's rig - that looks like the way to go. I did make something similar with just a series of holes instead of the slot. Don't remember why I stopped using it. The slidey bit and scale on Johns rig are really nice.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 25th May 2008, 04:26 PM   #17
Attention pinkmouse and others.
A tutorial on flush mounting is still needed.
But my question in here is:
After thinking this through and knowing how the pattern is made
how is the center material hogged out if the router base cannot
touch anything? How does the router travel across the center?
Old 25th May 2008, 07:01 PM   #18
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
I've recently made a jig like panomaniac's. I used aluminium channel, 2 pieces for rigidity. The pin is 5mm steel rod, hammered then epoxied in. I attach a phono of it along with my test fit using an 8" driver (the smallest it can do unfortunately).
I will need to mount some awkward shaped and small drivers soon too . I plan to mabye make a template from thick card cutouts layered together, larger then the desired routing path, and follow it on the inside with the copying bush. No idea if it'll work or how successful its likely to be, but trial runs can be made
Old 25th May 2008, 07:11 PM   #19
That looks like an excellent jig for round cutouts.
I'm hoping that router deal turns up during the Father's day sales.
We've seen the pattern required for the square flange on drivers
but the only method thaty Buike has mentioned is to secure the
patter by means of nails or clamps.
How can register be maintained for the center of the baffle?
Normally an "X" is scribed to find baffle center.
How can the pattern be registered on a baffle not the exact size of the
pattern without damage to the surface.
Registering is here used like is in the printing trade: lining up
identical pieces to do work.
Old 2nd June 2008, 11:13 PM   #20
I'm losing my confidence.
The more I try to freehand flush mounts for square drivers, the worse they get.
I have to make one of those pattern templates. The outlay and time will be considerable.
Doing it by hand, I always overshoot the corners and I have no good control over doing the arcs of the sides either.
Tweet/mid flush mounting Puggie Multi-Way 3 17th January 2005 06:11 PM
flush mounting subwoofers? Jhovis Subwoofers 1 30th December 2003 03:59 AM
Flush mounting anf cabinet geometry Dave Bullet Multi-Way 2 29th December 2002 06:46 AM
substitute for flush mounting Chris_W Multi-Way 8 9th May 2002 02:25 AM
Copyright 1999-2017 diyAudio
