Flush mounting speakers: the whole story Flush mounting speakers: the whole story - Page 4 - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 13th August 2008, 09:05 PM   #31
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by Steve Eddy
So I was able to import the pdf into CorelDRAW, delete all the superfluous stuff and use the outline of the mechanical drawing. Provided Fostexes drawing is reasonably accurate, it's just a matter of scaling it up to the appropriate size.
That is how i started out. In the end we had to start from scratch because the Fostex illustration was not accurate enuff.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th January 2013, 03:06 AM   #32
Siggma is offline Siggma  United States
Siggma's Avatar
I know this is an old thread but here's another trick to getting super clean circles on both sides using just a router and circle jig.
Set your circle jig and begin cutting your circle in small increments. Start with 1/4" deep at a time. When you get near to routing through leave 1/16" material at the bottom of the cut and stop the router. Now punch out the plug with your hands being careful not to tear, rip or otherwise mar the edge. Get out your panel trimming bit, looks like an upside down template bit, and finish the cut on the finish side. Panel trimming bits are used for installing Formica counter tops or trimming other veneers. They come in different sizes from 1/8" to about 1/2" with a bearing on the BOTTOM rather than the top. You could also use a round over, chamfer or any other pilot bit to finish the hole. Makes a very clean finish on the front of the baffle. Excellent idea if you are using veneer plywood and perfect for chamfering or rounding the inside opening for a small woofer.
"Scientific discoveries arise through discourse"
-Grissom
Flush mounting speakers: the whole storyHide this!Advertise here!
Tweet/mid flush mounting Puggie Multi-Way 3 17th January 2005 06:11 PM
flush mounting subwoofers? Jhovis Subwoofers 1 30th December 2003 03:59 AM
Flush mounting anf cabinet geometry Dave Bullet Multi-Way 2 29th December 2002 06:46 AM
substitute for flush mounting Chris_W Multi-Way 8 9th May 2002 02:25 AM
Copyright ©1999-2017 diyAudio
