battery powered pa rig question(s) - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd June 2008, 07:48 PM   #11
col is offline col  Australia
col's Avatar
If you use the JBL GTO937 6x9" in a small enclosure make sure you cut out all the low frequencies, otherwise they distort badly. I use a 200uF 100V Non-Polarised Electrolytic axial Capacitor on the positive terminal. This cuts anything under around 260hz. If you want bass you will need to compliment the system with a sub.
http://www.minirig.org.au
Old 3rd June 2008, 11:31 PM   #12
Banned
Personally I'd find a cutoff of 260Hz a bit restrictive, as calculating in the even-tempered scale, and taking International Middle A 440Hz, Middle C is 261.626 Hz.
Low C on the guitar (written as Middle C) is ~130Hz and Low E about 82Hz. This is not that hard to achieve in a portable system.
w
Old 4th June 2008, 08:12 AM   #13
col's Avatar
yeah, the JBL GTO937 is designed to be almost open baffle, to sit on a parcel shelf. If you put it in a small enclosure it doesn't like it much. I run mine as mid-highs with a pair of JBL SB2 subs continuing from 260hz down. I used to use the SureElectronics 4x100w module to power it all but have now changed to a 4 channel 41hz amp9-basic
Battery powered XO? MikeHunt79 Solid State 2 17th March 2008 03:19 AM
Battery powered PC ? percy Everything Else 15 7th March 2006 08:24 PM
battery powered gc in a tin digi01 Chip Amps 11 25th December 2004 05:11 AM
DC-33 DC Battery Powered Amp?? moe29 Pass Labs 2 26th April 2004 07:41 PM
battery powered RIAA preamp question Mad_K Analogue Source 8 27th October 2002 11:10 AM
Copyright 1999-2017 diyAudio
