Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Using Bulb in Place of fuse for testing
Old 4th May 2008, 03:56 AM   #11
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
In this amp, the power switch turns on a large toroid which is rectified for use as the main supply to the output stages
the first thing that happens is that a feed from those rails goes through a 1 amp fuse and then is dropped down to 15V that feeds a switching regulator. that supplies 15V to the front end boards. It does not have a shut down mode in this basic first stage. this is just the very first stage of many stages and power supplies that get powered up in sequence.
During trouble shooting i went through 3 or 4 fuses and i was running out. I had replaced all the bad components i could find and i didn't want to waste any more fuses trying to find the problems down stream.
I needed a way to isolate and protect that one stage within the amp. just putting a bulb in series with the main supply wouldn't have worked.
I was just about to try a bulb or just use my current regulated power supply to supply the 15V to that stage with the current fold back set to one amp when i accidentally found the problem.
Old 4th May 2008, 04:50 AM   #12
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
one thing that might help in troubleshooting switching supplies. try replacing all of the small electrolytics in it. they have a tendency to cause the circuit not to oscillate, or even worse, cause the semiconductors to overheat and short.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 4th May 2008, 07:26 AM   #13
Mooly's Avatar
Most sensible thing I've heard all day. I would add to that , that I use a 'scope for all D.C. measurements as well, it's suprising how often this shows up the problem. So many times I've seen techs measure a rail on DVM, say 11.2 volts for a 12 volt rail, and they think it's O.K. - near enough, the 'scope shows all, about 8 volts with a large HF component.
Regards Karl
Old 4th May 2008, 02:41 PM   #14
Zero Cool's Avatar
Crown did mention replacing 2 caps that can cause problems. I definitely will be doing that.
Old 4th May 2008, 07:32 PM   #15
Regards Karl
yup..... even on linear regulators, such as a 7812. had a projo tv that had all of the correct voltages, but had a nasty vertical problem. looked (with a scope) at the output of the 7812 that fed the vertical processor chip, and it was 10V dc with 4V p-p of vertical sawtooth superimposed on it. the 10uf/50V filter on the regulator output rail was open.
Old 4th May 2008, 07:49 PM   #16
Zero Cool's Avatar
Regards Karl
I have a Sencore Scope that has built in meter that can measure DC voltage, Volts P-P or Frequency from the probe. which really comes in handy!
Using Bulb in Place of fuse for testingHide this!Advertise here!
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 20 27th July 2016 08:11 AM
Dim Bulb Testing: What to Expect DreadPirate Solid State 4 25th September 2008 06:54 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 11:39 AM
Source for #81 light bulb for Hickok Fuse jamesjung21 Equipment & Tools 0 18th May 2008 08:45 AM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 10:26 AM
Copyright ©1999-2017 diyAudio
