| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I'm interested in making a device that takes 12vdc in and splits it 10 ways. 15A max current and 12-14vdc are the required specs.
I would like to involve polyswitches on the outputs for 6A each. Has anyone designed one of these or know of an easy way to do this? There are some commerical products but they are overpriced to say the least. |
#2 |
I do not understand what you want the device to do, as you don't "split" 12VDC into 12VDC. Can you describe the application or provide a link to a commercial product?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
#4 |
It's really nothing more than a bunch of connectors and circuit breakers shoved into a box. Quite ridiculously priced if you ask me.
Should be easy enough to build. Those 4-pin XLR connectors should be easy enough to source, as well as the circuit breakers. Then just find a plastic or metal enclosure that would work, drill some holes, solder some wires, slap it all together and you're done. |
| Anyone tried this 12vdc 1A supply? | dublin78 | Power Supplies | 1 | 11th June 2009 04:27 PM |
| Best way to power a 12vdc fan from 25vdc for an Aleph30 | hifimaker | Pass Labs | 16 | 16th December 2005 08:36 PM |
| How to get +15v and -15v from 12vdc | mbcouple | Everything Else | 15 | 25th June 2005 05:25 PM |
| 12vac to 12vdc what all do i need | Big_Tires | Solid State | 5 | 1st September 2004 11:33 PM |
| from 56vdc +/- to 12vdc +/- | kinser | Solid State | 16 | 17th August 2004 08:36 PM |
| Page generated in 0.09233 seconds (60.16% PHP - 39.84% MySQL) with 10 queries |
