Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd April 2008, 03:24 AM   #1
KOL69 is offline KOL69  Norway
Question XLR to RCA with attenuation pad.
Problem:
I'm using LynxTWO-B soudcard connected directly to a poweramp. There is a mismach in singal strenght (yes, I'm using -10dBV and not +4dBV) and I want to make a attenuation pad inside the XLR/RCA adaptor.
The output impedance of the card is 50 Ohm (unbalanced mode), but the manual also say: Output Drive Capability 600 Ohm(?).
The input impedance of the poweramp is 20 kOhm.
Should I make a L-pad (two resistors) or a T-pad (three resistors)?
Anyone out there that know where I can find formulas or information on how to make attenuation pads?
regards
KOL69
Old 24th April 2008, 11:10 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
You will need to put a resistor in series with each balanced output (these should be matched well), then you can either put a resistor (or potentiometer) across the balanced lines or a resistor from each output to ground to attenuate the signal.
Brian
attenuation using I/V ailouros6 Digital Source 14 15th October 2008 06:20 PM
hum attenuation AndrewT Power Supplies 3 2nd July 2006 09:12 PM
Attenuation argonrepublic Analog Line Level 5 23rd August 2005 07:22 AM
10 dB attenuation box june Parts 2 20th July 2004 04:07 AM
Attenuation Nappylady Multi-Way 3 18th February 2003 12:07 PM
Page generated in 0.07055 seconds (67.20% PHP - 32.80% MySQL) with 10 queries
