Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Paint Buildup/Pooling Around Cutouts
Old 20th April 2008, 11:07 AM   #1
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Default Paint Buildup/Pooling Around Cutouts
When you cut recesses for things like tweeters and sockets, do you find when spraying that you get paint pooling up making the edges not square/sharply defined? Is it wise to try and brush this out a bit?
I'm trying to work out how much to cut out for a Speakon socket recess. I'm working on allowing 1mm for paint thickness then 1mm spare all the way round.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 20th April 2008, 03:21 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
Why not just apply some to a piece of offcut, let it dry, saw through and check thickness...
Old 20th April 2008, 03:52 PM   #3
Did it Himself
That wouldn't quite tell me what I want to know. It's the pooling effect at recess edges (if it exists) that I want to know about, not the thickness on a flat slab, as I'd be aiming to put about 1mm paint on.
Old 20th April 2008, 04:16 PM   #4
TerryO is offline TerryO  United States
TerryO's Avatar
richee,
First off, that's a lot of paint. Are you planning on some sort of Metalflake Candy paint job?
Several people I know shoot some flat black around the inside of the recess and then place a cardboard circle with mylar taped edges in the recess that is slightly thicker than the recess itself. Even with this you need to be careful not to apply too much paint at the junction, or edge, of the "filler" piece.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 20th April 2008, 05:39 PM   #5
Did it Himself
I'm just going by what shinobiwan has said about how much he puts on, and one type of paint I'll be using is a heavy duty speaker coating that is thicker than the usual paint.
The masking idea is interesting but I think it could be pretty fiddly.
Old 21st April 2008, 02:09 PM   #6
KP11520 is offline KP11520  United States
KP11520's Avatar
The problem is caused by a term called Cohesion.
One suggestion is to let it settle and dry. Hopefully most of the excess will flatten as water seeks its own level (but with thick paint, who knows).
If it doesn't lay flat and look crisp, sand it flat with 200 to 400 sand paper (depending on how much build up you need to remove) and then a quick spray to cover the sanded area so it looks uniform.
Perfection is no accident and the closer you get the more frustration you receive. The only people who will truly understand the committment you made are the ones that made the same journey to the same level.
We all have to decide where the line is between pride for sweating the details and insanity! LOL. I tend to lean towards the insanity side. Please post a photo when you get the results you desire! Good luck!
Rather than paint, I wonder how powder coating would look and work! (never mind, this is wood.)
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Paint Buildup/Pooling Around CutoutsHide this!Advertise here!
bms 4540ND buildup? holger honda Multi-Way 11 20th July 2008 05:49 PM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
subwoofer buildup dodgedifferent2 Subwoofers 1 29th May 2005 01:18 PM
Denon DRA-350 heat buildup mpena93 Solid State 2 17th October 2004 08:04 PM
Heat buildup in sealed box? Nappylady Multi-Way 3 21st February 2003 05:58 AM
Copyright ©1999-2017 diyAudio
