Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th April 2008, 08:16 PM   #11
fluc is offline fluc  Canada
Thanks I_Forgot for the reply.
I will try it out.
Best regards,
fluc
Old 6th April 2008, 05:07 AM   #12
I_Forgot's Avatar
If the lamp (incandescent bulb) is working it will probably be warm enough to prevent icing.
I_F
Old 6th April 2008, 08:02 AM   #13
pinkmouse's Avatar
Surely it would be easier just to use a sealed microswitch, or a reed relay and a magnet in the button?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 6th April 2008, 08:28 AM   #14
rcavictim's Avatar
Default Keep It Simple......
Put up a sign made from freezing tolerant materials, (paper and felt pen works) asking people to knock. It works well and uses no electricity so it is good for the environment. As a bonus it acts as a filter which keeps really stupid people who cannot read from calling your attention to the door and wasting your time!
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 7th April 2008, 12:44 PM   #15
Default Re: Keep It Simple......
I am not sure that this would prevent the buttons from freezing. The problem arrises when it rains and then afterwards we get cold temperatures. The water accumulates and it freezes. we tried several types of buttons and none seemes to really do the job.
This would be a good option if there was only one door. This is for a large building with 6 different doors.
Old 7th April 2008, 01:39 PM   #16
BrianDonegan's Avatar
I would not call them inexpensive, but there are many illuminated vandal proof buttons that are designed for outdoor use.
Here's the cheapest one I could find (quickly): http://www.mouser.com/Search/Product...7YpLJirw%3d%3d
It's zinc, but should work fine. You could also go with stainless steel.
To power the LED, add a diode and resistor.
Good enough for an outdoor ATM.
Twisted Pear Audio
Old 7th April 2008, 04:42 PM   #17
dnsey is offline dnsey  United Kingdom
Fit the switch inside the house, and run a PTFE pushrod through the door/frame to operate it.
Old 8th April 2008, 01:04 PM   #18
Thanks BrianDonegan. I am looking into it.
I would like to thank everyone else for their replies. I appreciate all the info and ideas I got. I will let you know how we make out.
Kind regards,
fluc
Phillips CD player - can I replace a PCB pushbutton switch? rwtomkins Digital Source 27 24th July 2008 01:25 PM
Piezo help shawn1972 Multi-Way 23 6th September 2007 07:09 AM
pushbutton power circuit tsjdesign Parts 9 11th December 2003 05:54 PM
Page generated in 0.09996 seconds (76.30% PHP - 23.70% MySQL) with 10 queries
