Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Advice: Dog Silencer Modification for enchanced range & intensity
Old 20th February 2009, 02:39 PM   #31
CyberDrool is offline CyberDrool  Australia
Send a message via ICQ to CyberDrool
Yeah...
Quick, easy and very satisfying.
And then you have to live with 400 ********, and barking will be the least of your problems.
Old 20th February 2009, 02:39 PM   #32
Oops, it was the post about the shotgun I was replying to.
Old 20th February 2009, 03:36 PM   #33
Steerpike is offline Steerpike
Steerpike's Avatar
neighbor's TV set silent at 3 AM
A pin through the co-ax feed ought to make it unwatchable enough that they switch off.
Unless they're watching satellite or DVD.
Maybe you should take up an interest in DIY Tesla coils.
Old 20th February 2009, 05:14 PM   #34
Badge is offline Badge  United States
I purchased a Kemo MO71N ultrasonic vermin repellent. It has a built in piezo and adjustable frequency control. It also has a speaker out for attaching another one of their speakers. It works well but does not produce enough output. I need to figure out how to reduce the voltage coming out the speaker out to drive amp and array of tweeters. This might work for you as well.
The freaks stick together, they are a tight old crew
Old 25th February 2009, 10:00 AM   #35
OzMikeH is offline OzMikeH  Australia
Get a petition from the neighbours.
Also check your local laws.
Should that fail bang on their front door every time their dog barks day or night. As soon as they open it say DOGS! and walk away.
Help some guys with funny hair bang two rocks together really hard.
http://athome.web.cern.ch/athome/LHCathome/whatis.html
Old 4th September 2009, 03:58 PM   #36
SpyStyle is offline SpyStyle  United States
Hello from Maine
I have the same problem, inconsiderate neighbors that have loud dogs, they won't listen top me and deprive my child from sleep
Not to mention the dogs drive me insane!
I found something via Google that might help, it's called "shut that mutt"
http://www.megaupload.com/?d=2GRLT9AE
I wonder how the OP ever solved his problem? I can't want to solve mine
It should be legal, nay mandatory, to stab inconsiderate dog owners... over and over and over ...
Old 5th September 2009, 01:24 PM   #37
It looks like you can buy that already built here :
http://tinyurl.com/ldygtn
I ordered one off eBay
Old 12th September 2009, 03:50 AM   #38
pheonix358 is offline pheonix358  Australia
pheonix358's Avatar
If you want to shut up the dogs you must train the owners. Use Pavlov conditioning. Google it. Now, sneak into the neighbours, connect to their 110 or 240 power supply and run the wires back to your place. These wires must be well hidden. Connect a 5 or 6v high current transformer the wrong way around and wire in a momentary push button. Isolate everything so it is safe. If neighbours anoy you push button. On a 240 volt mains a 6 volt transformer will deliver 9.6kvolts. When they come and sak if you have electrical problems say no! They will eventually sell up.
What we don't understand is called magic.
Old 12th September 2009, 12:01 PM   #39
Well the device I ordered seems to be working, I'm not sure though - coincidentally the weather got cold right around the same time I installed it so I guess the dogs are outside less (?)
So I did hear barking but it was short - like one bark or one string of barks, but that's a lot better than it was before. I can move the device closer too. Just having the device really gives me peace of mind for previously unsolvable problem
We'll see how it goes.
If dogs are driving you crazy take action, brooding doesn't accomplish anything
Good luck,
Craig
Advice: Dog Silencer Modification for enchanced range & intensityHide this!Advertise here!
Vintage Full range- Need some cab advice waam68 Full Range 7 19th August 2008 09:30 PM
Full Range Dipole Designs - Any Advice? Forster Full Range 5 9th January 2007 01:13 PM
Need advice- tweeter for close range... eRiCdWoNg Multi-Way 8 30th April 2004 09:16 PM
Advice on full range enclosure for 5.1 setup CDJ Multi-Way 3 21st January 2003 05:28 AM
