| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I've just bought a load of BHC caps off of Ebay, and very nice they are too.
But, they have 4 leads. What is the pinout for 4 legged capacitors? Is one of them -ve, the remainder +ve? Cheers, Phil |
#2 |
1= positive(+)
5= negative(-) 2 and 3= nothing(for solid connection on the board) |
#3 |
2 input leads, 2 output leads
check their website for terminal location. got any to spare? |
#4 | |
#5 |
Well, it depends on which model you are talking about. If it is the 4 terminal series like the following, they are not just supports:
http://www.bhc.co.uk/pdf/aln20s.pdf |
#6 |
Phil,do you've a pic of the capacitor or can you give the exact numbers?
#7 |
I'll try and sort out a photo later on. It does indicate that pin 2 should be negative (although pin 2 appeared ambiguous last time I looked), so I assume the others are either all positive, or just one, and the remaining two are support. BTW meanman, "1= positive(+) 5= negative(-) 2 and 3= nothing(for solid connection on the board)" Did you mean 4=negative? Thanks for all the replies. I don't think its anything like pooge suggested, but I could well be wrong. Its a 4100uF 70V electrolytic, and its blue Cheers, Phil |
#8 |
Here's the picture of them used on Ebay, if it helps.
I'll take a more sensible picture tonight. |
#9 |
When you look at the pins are there no numbers stamped in?
#10 |
Yes there are numbers, but if I recall, it quotes one of them as negative, and the rest are not described.
Anyway, they look like they're maybe ALP10A caps, so I'll see if I can find the datasheet. |
| Marshall Mosfet LEAD 3210 blowing power fuses - help locating capacitor(s) | jmilch | Solid State | 13 | 20th August 2009 05:31 AM |
| Time to get the lead out | icanryme2002 | Multi-Way | 2 | 17th December 2007 02:54 AM |
| convert Lead Pb-206 to Pb-205 | jacquesl | Everything Else | 2 | 4th February 2007 10:39 AM |
| lead vs sand | IZHAKKATZ | Analogue Source | 15 | 4th November 2004 04:21 PM |
| Page generated in 0.08705 seconds (77.81% PHP - 22.19% MySQL) with 11 queries |
