| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 | |
I can see a number of problems this set-up that I think would make it a very unreliable way to check resistor "directivity" or any other aspect of component "sound". This unshielded arrangement is going to be prone to all sorts of radiation and noise pickup. There's a good chance that such noise will mask any effect of component "directionality", if any exists. Then there's the contact method. Just relying on the spring force the leads provide is an extremely poor way to make contact with the part. Every time you move it (or some sound in the room vibrates it) the characteristics of the contacts will change. The plating on the component leads and the plating on the connectors may be different materials forming point contact diodes. Dirt or crud on either the leads or the connectors will interfere with the connection. I think a better test would be to build two identical amplifiers with all the components matched and installed with the same "polarity". Build it in a properly shielded enclosure and use a quiet power supply. Feed the same signal into both amps, then observe the difference between the outputs. This will be the baseline. Next reverse the one component in question, and observe the difference between the outputs. I would use a simple amplifier such as a very low noise, low distortion, wide bandwidth op-amp, one with multiple amps on a single chip to ensure that they are matched. The outputs of those amps would drive a similarly low noise, wide band, low distortion instrumentation amplifier. Observation would be done in both frequency (spectrum analyzer, noise analyzer, etc.) and time domain (oscilloscope, freq selective voltmeter, etc.). Several different test signals, steady and dynamic, could be devised and applied to the circuit to check specific aspects of the behaviour. Such a test set up would require a lot of time, money and effort. Not many people have the access to such equipment. Even fewer of those who do would be interested in performing such a test. Oh well... MR
Keeping an open mind since 2002... |
#12 | |
If this differences are consistant in subsequent testing for certain brands of resistors, I'm ruling out poor contacts factor. I made the tests in a period of 20 minutes, so I ruled out changing conditions as well. Why don't you try it yourself and agree with me? I did quite a few tests of this type and can assure you that quality of the contact is not a problem here. Controling vibrations ibrations is a totaly different issue.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 | |
se |
#14 | |
#15 | ||||||||
Steve,
Do you find any subjective differing directional results ?. If you do, then there must be a physical reason, yeah ?. Quote:
I do use my DPDT transformer arrangement so that I can easily select AP at my speakers, but that was not my question. BTW - are you saying that you cannot hear AP ?. Quote:
Go and read the thread that Frank refers to above and you will be clearer on what we mean. Quote:
How exactly can your mind be sub-concious ?. Quote:
In my younger years I read the brocures, and believed the spiels to be true. When the salesman plugged in say, 'Monster cables', and said "Hear that better bass ?" etc, upon that power of suggestion, I did. On subsequent learning, and far greater experience, I now do not pay the merest heed to such suggestion. In my formative years, I did indeed perform experiments, and automatically considered them to be beneficial. In later experimenting, I have learned that one can make very fine audible differences, but these are not always beneficial fine differences, especially with long term listening. I am now well enough practised in this, that I find that I have a long term listenability/enjoyability handle on a new sound in about 5 seconds, and that these impressions prove to be accurate longer term. Quote:
Within my experience, I fully expect that C37 and Tubolator do affect/effect system sound, however based on my experience, I am not sure that the effect is particularly significant, nor entirely likeable - this requires personal experience of these products, and that I do not have, and my soloution is quite different. Eric.
I believe not to believe in any fixed belief system. |
#16 | |
If you want to do such a simple test setup and use only ears to evaluate the result, then shield the thing (just put it in a grounded box), an connect the resistor or other part to be tested using some binding posts or nuts and bolts and use a torque wrench to tighten the nuts uniformly and repeatably. Whether THAT is a valid test is still debatable, but at least it should lead to repeatable results with minimized "noise". There is another issue to consider- do resistors sound the same when they have only ac signals across them? Does ac + dc cause different sound? Does dc polarity and level affect the sound? If none of this matters, and the whole point of the exercise is to fool yourself into thinking that you have actually tested something and have some valid results then your test set up really is optimal. MR
#17 | |
#18 | |
se |
#19 | |
I also have 20 years of experience in testing and devicing test methods. I, however, have absolutely no problem with the set-up when the intention is a quick test for the claimed differences. Sure the set-up is not "scientific", flawless or even close to perfect but that does not mean that it is completely useless. I don't argue the fact that there are OBVIOUS flaws in the test set-up but any flaw does not automatically disqualify all results from a test. The concept of repeatability also helps in the value of the results in this case.
UrSv Those who say it can't be done should not stop those who are doing it. |
| Bass directionality etc. | Kongen | Multi-Way | 3 | 17th August 2007 04:24 PM |
| Directionality of V-Cap TFTF? | Colescuttle | Parts | 1 | 17th October 2006 08:15 PM |
| Resistor Sound Testing | DragonMaster | Everything Else | 18 | 2nd February 2006 11:34 PM |
| Resistor testing and directionality | Bobken | Everything Else | 29 | 18th February 2003 10:42 PM |
| Page generated in 0.16249 seconds (86.40% PHP - 13.60% MySQL) with 11 queries |
