| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have a portable CD player that I use as a music source on my motorcycle. I place the player in a saddlebag and have a cable that connects it to a pair of amplified speakers which are mounted on the handlebars. I need a way to adjust volume that I can use while riding. I have a little inline volume control from Radio Shack but it is too small to adjust when wearing gloves. I would like something I can install in my dash with a decent sized rotary knob. Any suggestions as to something I can buy or build with off the shelf components?
#2 |
Just get a dual 500K log potentimeter, then wire this in line with the speakers. Should work fine.
#3 |
Thanks for the reply.... where can I buy a dual 500K log potentimeter?
#4 |
Just go to your local radio shack and buy one, only costs a couple of dollars.
Then wire it so you have the output signal wires (red & white) of the player going to the middle connections (wipers), the signal wires to the speakers on the RH side and the earths on the left. Typically the earth will be the copper wrapped around the red and white signal wire. |
#5 |
noooo!
this way you will short circuit the player's output at low volume! you have to do like that: player's input to the top connector, player's ground to bottom speaker to the middle connector, and speaker ground to bottom |
#6 |
Thanks guys. Here's another idea... what if I use a motorized pot and added a small switch to the handlebar to control volume? This would allow me to control volume without having to take my hands off the bars.
http://www.mouser.com//index.cfm?han...oductid=378686 How can I reduce 12 volts DC to the voltage required to operate the pot motor? What type of switch should I use to operate the pot motor so I can adjust the volume? Sorry for the trivial questions... I'm more mechnaically inclined than electrical! |
#7 |
Umm. yes. thats what I meant! Whoops...
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| volume control | morpheus82 | Everything Else | 1 | 18th August 2005 02:27 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Page generated in 0.07745 seconds (75.91% PHP - 24.09% MySQL) with 10 queries |
