| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#31 | |
My 'not fully educated on the specific subject' thoughts would be the calculation of the calorimetric loss in the fluid vis-vis thermal transfer issues. That can only be approximated so much, is my conclusion. And if you are that critical and that close, it's gonna play at the heart of what you are trying to get to, ie, accuracy. But I'm sure you are well aware of all this anyway. oh..I see the disc is gone. I guess the best you can hope for in the long run is having only funny stories and and a battle scar.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#32 |
Thanks KBK, feeling better today already!
Actually the disc isn't gone... the disc is still quite thick and robust. All that is gone is the portion that tried to invade the spinal canal. I've had 3 bad discs... out of 360 degress to protrude... each one has decided to head right for the spinal cord! Yep... calimetry is a pain... I do it on some stuff... but it just a pain. Stray heat loss, parasistic/assorted heat capacities, and test time, just make it a PITA... pure and simple. |
#33 | ||
Good to see you're back. Glad it went well.
You can also try stainless flux. I use it for soldering to nichrome as well as stainless steel. Takes some technique, but I get a really good coat of solder on both. Once you've coated the wire, you can easily solder the coated section. (do a good cleaning after you've coated the wire though, before the final solder.) Quote:
Cheers, John |
#34 |
Thanks John,
I haven't messed with trying to solder a sample yet... but those tips sound on the mark. I am just trying to get through the day and 400 emails without drugs... OUCH! |
#36 |
| high precision high voltage supply | nhuwar | Planars & Exotics | 13 | 12th February 2007 08:24 AM |
| Precision resistor source in Australia | wintermute | Parts | 9 | 19th December 2004 07:58 PM |
| Spectrol, high precision, 10k attenuator. | Peter Daniel | Swap Meet | 3 | 4th February 2004 05:15 PM |
| Precision and/or high performance SMD caps | peranders | Parts | 21 | 17th April 2003 12:08 PM |
| Page generated in 0.10489 seconds (78.95% PHP - 21.05% MySQL) with 11 queries |
