Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
ROHS - Green or Madness ?
Old 30th January 2008, 01:36 PM   #31
megajocke is offline megajocke  Sweden
megajocke's Avatar
Originally posted by Eva
The voltage across the lamp suffers an abrupt polarity change with ringing everytime the ballast current crosses through zero. Starters include a capacitor to reduce dV/dt but it actually becomes quite ineffective and trades a lower ringing frequency for stronger ringing. You may wish to check if this fluorescent system has a power factor correction capacitor fitted, as it could improve EMI by confining some of the RF in the lamp-ballast loop.
Ironically, a good high-frequency switching mode ballast may produce less EMI (plus the usual advantages: increased light output, longer lamp life, fixed starting time, less power wasted as heat, etc...)
It's a tabletop lamp with a 1 metre cable (antennae!) connecting the ballast to the lamp. I doubt the capacitor can fix that! I think I'll replace it with an incandescent or halogen bulb, the fluorescent flickers erratically too. But that seems to be a problem with the mains power, the lamp in the bathroom does it too. The mains voltage waveform looks almost like a trapezoid... Is it supposed to be like that?
(The requirement for PFC in new products might not be as stupid as RoHS though!)
Old 30th January 2008, 01:48 PM   #32
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
then they'll have to ban CCFL's.
Old 30th January 2008, 01:51 PM   #33
phase_accurate is offline phase_accurate
So does my ex-wife's cooking.
Now I know why I always had the feeling of talking to a ghost !!!
Charles
Old 30th January 2008, 02:38 PM   #34
megajocke's Avatar
Haha! But I believe the power factor is pretty good to begin with though, good luck getting a big filter capacitor in there. If the filter capacitor is reduced in value the power factor will be better at the expense of 100Hz flicker, which might not be a problem. It's all those computers and TVs that mess up our mains waveform.
But really, I think it's quite stupid cramming those electronics into the base of the lamp with almost no cooling. An external ballast will last longer with the same components and there will be no problem fitting a PFC correction circuit. And when the lamp goes out you don't have to replace the ballast. Why do we have to use the edison type screw base for fluorescents? It's a wonder it has not been banned due to its easily accessible live parts. Even worse than the standard US mains plug that you can pull out a bit and connect your europlug at a right angle to it.
Old 30th January 2008, 03:02 PM   #35
Do you find that inconvenient ?
Charles
Old 30th January 2008, 08:32 PM   #36
ak_47_boy is offline ak_47_boy  Canada
It's all turning into one big socialist nightmare.
Old 17th February 2008, 05:01 PM   #37
EnvisionAudio is offline EnvisionAudio  United States
EnvisionAudio's Avatar
Indeed!!
It's a pity that you are only getting the low quality pale white CFL stuff in the US. The warm white ones are quite different.
There are three color temps available here in the local big box hardware store, Home Depot. Cool White, Bright White and Warm White. Cool white looks bluish and is very high color temp. Bright white is closest to incandescent and Warm white is too orange for good color rendering. It's akin in K to a dim incandescent.
Unfortunately, many of the "name brands" such as Phillips are terrible in color rendering and start-up (very dim, increasing in brightness).
DCX2496/DEQ2496 Car Audio Conversions
www.envisionelec.net
Old 27th January 2009, 09:30 PM   #38
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Seen on the new packaging of GE's compact fluorescents -- words to the effect of -- and I paraphrase: don't use these things near sensitive electronic devices -- they emit in a range of 500kHz to 30MHz -- most of the a.m. broadcast band, short wave listening and ham frequencies.
FWIW, our town dump just posted a sign that they will no longer take fluorescents or their CF variety.
just what we need, more e-crud -- gonna be great for the old hammond transformers, however.
and I note that CFL's should not be used in recessed fixtures -- they can overheat. this was pointed out in EDN back in October and is now on the packaging.
ROHS - Green or Madness ?Hide this!Advertise here!
ROHS vs non-ROHS compliant components mtl777 Parts 4 24th January 2008 07:34 AM
The RoHS Fiasco zapnspark Everything Else 9 6th October 2007 04:36 PM
OFC madness koolkid731 Class D 2 9th March 2007 12:34 PM
Project madness whitelabrat Tubes / Valves 7 19th February 2007 01:50 PM
iPod/SET MADNESS! Tutordennis Digital Source 1 13th October 2004 03:32 AM
