ROHS - Green or Madness ? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th January 2008, 02:02 PM   #11
I assume that more electrical energy would be saved if it was forbidden to illuminate empty office-buildings and department stores at night than changing the light bulbs.
Charles
Old 29th January 2008, 02:04 PM   #12
jackinnj's Avatar
Originally posted by SY
Jack, have you red Rod Elliot's rants about CFLs? My lab lighting is CFL now, and to make a low noise measurement, I have to turn them all off.
Long time ago.
Perhaps 10 years ago there was an article in EDN about fluourescents and diodes -- seems that a fellow was trying to do some precision measurements and kept getting bizarre results -- the pulsing of the flourescents was illuminating some diodes and altering the current.
After all the incandescents have been chucked we're going to find out that the CFL's cause hyper-activity in adults. If you ever look at the spectrum of these lamps you're gonna understand why some folks prefer vinyl to CD's --
Old 29th January 2008, 02:51 PM   #13
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I have been using CFL for 20 years now, I started with the ones that had a conventional ballast rather than a high frequency one. Nowadays there is a wide selection of CFL with varying quality, ranging from the cold white Chinese stuff with noisy ballasts that also produce quite a lot of heat (and probably UV) and are available in up to 32W, to the higher quality warm white Philips stuff (that does no longer seem to be available in high power >15W versions).
Anyway, I find that conventional fluorescent lamps with conventional ballasts are far more noisy, both electrically and acoustically. There is usually substantial RF ringing at zero crossing.
I use to feel like the small child in The Emperor's New Clothes tale
Old 29th January 2008, 02:57 PM   #14
jackinnj's Avatar
Charles
This is coming -- in the U.S. there will be "dark" laws which prohibit night-time illumination of building exteriors -- so we will look like I recall Prague and Dresden back when I first visited in the 1960's. Worst are the suburban homes with the trees iluminated at 3:00 in the morning.
All of the lamps generate some heat and it can be more economic to load the building with some heat continuously -- rather than trying to warm a cold building at 7:00 in the morning. That's why we have pointy-headed guys who know a lot of calculus. It's not just the physics, it's the KWH charge which varies during the day and the thresh-hold points for surcharges. The electric co's work with folks, however, since it is in their interest to optimize their capital expenditures.
I have never met a politcian who took calculus or statistics.
Old 29th January 2008, 03:11 PM   #15
SY's Avatar
More importantly, there's damn few politicians who have ever taken a course in thermodynamics.
Eva, the CFLs available here (through government subsidy) are all the cheap Chinese ones. When they're on, they radiate all sorts of hash.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 29th January 2008, 03:39 PM   #16
sts9fan is offline sts9fan  United States
The laws could be misguided but Pb is a poison and if there are alternatives thay should be used. Also I don't remember how much Hg is in a light bulb 5mg? How does that waste compare to that of the coal plant? Does the use of these bulbs use less coal? Is there a net loss in Hg output?
Old 29th January 2008, 03:49 PM   #17
jackinnj's Avatar
Probably becuz you have to take Calculus 101 and Physics 101 to get to Physics 102.
Old 29th January 2008, 04:04 PM   #18
jlsem is offline jlsem  United States
jlsem's Avatar
we also have the 3.8 litre flush toilet -- which costs 5X that of an ordinary toilet.
The gallon/flush toilet idea (thanks Al!) doesn't work that well anyhow because more often than not one has to flush two or three times to get everything to go, and on the the really big jobs your business has to be divided to prevent stoppage. Same thing with RoHS solders - way more energy is used to get the joint right than with ordinary 63/37. I have been exploiting the Solen sale page for a year now - in this case I am able to gain from government silliness.
John
"Those who abjure violence can do so only because others are committing violence on their behalf." - George Orwell
Old 29th January 2008, 05:28 PM   #19
Bobken is offline Bobken  United Kingdom
I haven't seen anyone else mention this yet, but what concerns me about this RoHS directive is that lead-free soldered joints have an adverse effect on ultimate sonics.
I believe this is due to the joints (however carefuly made) being always dull in appearance and rough-surfaced compared with a shiny 'conventional' joint with a meniscus or fillet of solder running up the lead of the component.
Lead-free solders just don't properly 'wet' the parent metals like conventional solders do, and the new alloys formed during soldering between the copper (or whatever) leads and the traces, are brittle and just not as strong and can be broken apart more easily.
I earned my living through soldering (by hand) for some years and learned just a little bit about this subject at that time. I used to compare entire PCBs which had been soldered with different solder alloys, but which were otherwise identical, and the results can and do sound different. Currently I have 8 different solder formulations (and 5 fluxes) but will not use lead-free for anything by choice for DIY, although we cannot avoid this now in any commercial work. As someone else has said, more heat is needed, anyway, with lead-free and the results are not as good from the aspects of longevity, strength, and (for us) sonics, and that is why there are certain 'dispensations' for life-support/critical applications.
Furthermore, I have more lead on my roof than will be in all of the electronic circuit boards in the town where I live, and this is being constantly 'washed' 24 hrs a day by more acidic rain than used to be the case. Lead is a fairly benign metal, I know, but it does erode over time and forms white 'salty' deposits which will be washed into the ground or into the local drainage systems.
Locally, I know of several civic buildings and churches where there are thousands of square feet of exposed lead on their roofs, and no-one turns a hair about this, but lead came out of the ground originally as lead ore, anyway. I don't know about the miners involved, but in Cornwall (UK) where lead was mined years ago, I don't think that there were any special health issues, and the locals were sitting on top of thousands of tons of lead ore at one time, until it was all dug out.
Somewhat regrettably, I am old enough to remember that all of the domestic water pipes in the UK at one time were just plain lead, and we bathed in, washed our clothes in, cooked our food in, and innocently drank this water, all of which had come through lead pipes.
It really is quite ridiculous!
Bob
Old 29th January 2008, 05:40 PM   #20
SY's Avatar
This explains a lot.
ROHS vs non-ROHS compliant components mtl777 Parts 4 24th January 2008 08:34 AM
The RoHS Fiasco zapnspark Everything Else 9 6th October 2007 05:36 PM
OFC madness koolkid731 Class D 2 9th March 2007 01:34 PM
Project madness whitelabrat Tubes / Valves 7 19th February 2007 02:50 PM
iPod/SET MADNESS! Tutordennis Digital Source 1 13th October 2004 04:32 AM
Copyright 1999-2017 diyAudio
