Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd March 2003, 06:04 PM   #21
Audiofanatic's Avatar
Hi Gaz,
You can do that without any problem.
But! Be shure to use the best tape you can buy!
I use the best glue there is, from BISON.
Are you going to make it with pvc isolated wire or with perforated metal?
I wish you luck with your plans.
Audiofanatic
Be nice to animals.
Old 3rd March 2003, 08:25 PM   #22
Rarkov is offline Rarkov  England
Rarkov's Avatar
Send a message via ICQ to Rarkov Send a message via Skype™ to Rarkov
Before I go on, it'd be rude not to let you know how beautiful your ESLs are!!! Fantastic work. (Or are they what you made clones of?) Either way - excellent!
I have got the Mylar. I ordered it from One Thing Audio. I believe it is used for repairing Quad ESLs (66? Something anyway!). Unfortunatly it is about 23microns thick which is more than I wanted, but hopefully I should get quite a bit of tension.
I am sourcing some 1.5mm or 2mm acrylic for the spacers (about 1.7mm seems to be optimal but hopefull 1.5 bulked out with tape will do it). Finally, the stators are the only thing I haven't sourced. I am getting quotes on 1.5mm mild steel perforated plates with 50% coverage of 3mm holes. I will get them powder coated (only £25 for all 4!). One company quoted £80 for the mild steel!!!
Does this sound OK? Will it make much difference if a D/S spacing is 2.1mm instead of 1.7mm? Does that sound right by the way. Sounds like an awfully small gap to me!
Thanks,
Gaz
Old 3rd March 2003, 10:31 PM   #23
Hi Gaz,
The ESL's are the original ones, I'v made a clone of those.
The Mylar is to thick, you'll see when you'r ready to listen to your ESL's.
I can send you 4 or 6 micron if you want via a friend of mine, 80cm resp. 100cm wide.
The gap is o.k! the bigger the gap, the lower the db!
I'm going to bed now.
I'll continue tomorow
Audiofanatic.
Be nice to animals.
Old 5th March 2003, 08:29 AM   #24
peterr is offline peterr  Netherlands
peterr's Avatar
This really is very thick. I can't imagine Quad uses this.
I use the 6 micron variety Audiofanatic speaks about and it is very good. It is also in the link in my first post (the stuff from MartinJan Dijkstra).
I too used tape to glue the mylar to the spacers but I have used glue (bisonkit it is called in holland) to fix the spacers to the frame.
My D/S spacing is 2mm. I would rather go to 2.5mm then to 1.5mm if you intend on using your ESL at or close to full range.
Make sure to have your metal powdercoated at least twice maybe even three times to create a thick enough insulation layer.
Also I read somewhere (did not test it myself) not to use black paint as it contains carbon particles (to make it black). This gives it a much lower resistance at these high voltages.
Good luck
Keep an open mind. It helps.
Peter
Old 5th March 2003, 10:20 AM   #25
ashok's Avatar
Default Be extra careful.
I am also working on an electrostat. I just wanted to caution all those new to DIY and especially working with ESL's, be VERY CAREFUL about the voltages. Use rubber gloves when working with powered units. These devices can shock you VERY badly if not KILL you if you touch live parts. Remember that the ESL is a capacitor and so can store a charge at very high voltages. While these are highly resistive , the power transformer/power supply and step up transformer are especially lethal. With kilovolts around you can even blow a normal DMM !!
BE CAREFUL.
Cheers.
AM
Old 5th March 2003, 11:23 AM   #26
Rarkov's Avatar
Don't worry. I'm exceedingly wary of Power Supplies. I had no prior knowledge of high power PSUs when I built my monoblocks with 500VA PSUs, but I did it, and I'm happy with them, but I certainly do not go poking around in them...or if I have had to quickly discharge large caps, it's been on the end of a long screwdriver!
I will be even more wary of kV sized PSUs! Out of interest, if using a DMM with a step down resistor network, how far can I expect the PSU to spark to the probes (or me) when I go to measure them. Will there be a spark at all?
BTW: How much would people expect to pay for perforated sheet mild steel with the following specs:
2mm thickness (2000mmx1000mm)
50% hole coverage.
3mm hole at 4mm pitch
£72.76 per sheet (need 2!)
Thanks,
Gaz
Old 18th July 2003, 08:44 AM   #27
wrl is offline wrl  United States
Does anyone know where to purchase the audio step up transformers?? I tried the electrostatic loudspeaker exchange, but they seem not to be answering their e-mails and their phone line is disconected. HMMM methinks a bad sign.
Anyway, if anyone knows where I could get these it would be appreciated.
Thanks,
Wes
Old 18th July 2003, 10:21 AM   #28
ashok's Avatar
Default Winding your own.
I think this is probably a bit like winding audio transformers for a tube amp. Only hitch is that it uses higher voltages on the secondary and so insulation schemes will be more important.
Has anyone started winding an audio output transformer yet ?
If you have never wound a transformer - it might be much better to buy one.
Cheers.
AM
Old 18th July 2003, 10:25 AM   #29
ashok's Avatar
Default Check this ...............
http://www.justrealmusic.com/content/transformers.htm
and
http://www.amplimo.nl/en-us/dept_30.html
and
http://www.sowter.co.uk/esl.htm
and this
http://www.audiocircuit.com/9041-esl...U/9041DMAU.htm
One of these may solve your problem.
Cheers.
AM
Old 18th July 2003, 05:02 PM   #30
316a is offline 316a  England
316a's Avatar
Default Transformers
Cheers.
Why not try using a 240V:6V mains toroid ? After all these should be able to provide wide bandwidth and a turns ratio of 1:40 . With an ESL , bass will not be required so core saturation will not be a problem , should work (in theory) .
Rarkov : I'm also building an ESL . A good source for mylar is model engineering suppliers . My 5 micron mylar was £5.00 for a 10mx30cm piece . Farnell have suitable double sided acrylic tape and foam tape suitable for spacer adhesive . Is this what you were planning on using ?
316a
FS 12 micron Dupont Mylar nautilus Swap Meet 3 19th December 2007 12:39 AM
1/2 mil Mylar for ESLs phishead8 Planars & Exotics 12 17th December 2001 04:05 AM
Page generated in 0.12219 seconds (81.20% PHP - 18.80% MySQL) with 11 queries
