I am trying to source some 0.5mil (12.7micron) DuPont Mylar Film in the UK. After mistakingly quoting 2microns, I was knocked off my chair with £200 for 3mx49cm! When I finally got the correct data, it was quoted as £60 for 3mx30cm. Does this sound right? I need a larger width than 30cm though...Anyone know where to get it in the UK? It needs to be more like 50cm.
Please help!
Thanks,
Gaz
Please help!
Thanks,
Gaz
I don't have the link handy, but someone on this forum has mentioned that someone in the US sells Mylar in a form that allows the builder to take a hair dryer and shrink it to a perfect fit once it is installed. He gives a supplier. I don't believe it was terribly expensive. You might try a search here on the forum.
The only thing I could add, apart from peterr's link, is here in the US they sell 2 foot by 3 foot sheets of Mylar for gift wrapping paper. They come in packages for a dollar. So the stuff should be cheap, assuming you can locate a supplier.
Good luck.
Good luck.
Absurd?
Absurd is a very mild term for that price (60/- pounds).
I bought some from the US by mail order. I paid some US$20 I think some 3 years ago. Look for ESL on google and it will come up. I also bought two transformers from him. I am getting old, I forgot his name for the moment. It came folded ( not very sharp bends).
Its about 48 inches by 36 inches I think, maybe a bit bigger.
About the same time someone posted a message on the ESL web site ( can't remember where!) that he bought a whole roll in Tokyo for US$80 or 100/-. That was about 36 inches wide by over 100 feet - or was it meters! I remember thinking that my price was about 10 or 20 times more. Better you guys get together and see if you can buy left over rolls from electrolytic capacitor manufacturers.
Cheers.
these prices are absurd
Cheers.
Hi Guys,
Try Rob Mackinlay - E.R Audio in Western Australia @ www.eraudio.com.au for all things ESL!
He sells 12um mylar for $1.10US per meter X 800mm wide. Also, supplies the dielectric coatings; transformers; rectifier blocks etc. and full range ESL speaker Kits at very reasonable prices.
Just a little tip, the 3.8um micron Mackinlay supplies is much better than any other thickness, being significantly more detailed and transparent sounding. I currently use and listen to E.R Audio's ESL-3 full range electrostatic loudspeaker...it's a wonderful speaker! Having much better transient response and micro-dynamic detail retrieval than any Quad ESL; Accoustat or Martin Logan I've owned or heard.
I will do a full review on the ESL-3 on this site in due course.
Steve M.
Steve M.
In the US McMaster-Carr has 5 or 6 micron polyester film, though the size may be limited. They also have perforated steel and aluminum sheets to use for the stators.
When you specify "Mylar" you get DuPont's product- Mylar is their brand name for polyester film. You can use any manufacturer's polyester film with excellent results. The film I use is called "Lumilar" and is made by a Japanese chemical company called Toray.
I would not make speakers using only a heat gun or hair dryer to tension the film. You can not get much tension that way so your speakers will exhibit very low sensitivity because you'll have to keep the bias voltage down to keep them from flapping. You will need to make a mechanical stretcher. Such a device will allow you to put a huge amount of tension on the film and run your bias supply at maximum possible voltage, thus giving you a speaker that can be driven to very loud levels by a "normal" power amplifier.
I have posted photos of a pneumatic stretcher I use on these forums - do a search. The stretcher is extremely easy to make and use and you won't regret trying it out.
MR
MR
Sorry for the delay in replying...
Thanks for all of your helpful posts. I have sent a cheque off to One Thing Audio (from a link in peterr's link). The owner is charging £30 for 10m...That far more like it. The is very little possibility for finding "scrap" / surplus parts for the ESLs around where I live, so it's going to be a long, slow and expensive exprience!
BTW, I've had a couple of ideas...
1) I have a dog and I am a bit jumpy about the idea of his wagging tail hitting things it shouldn't! (He's a v. long haired English Collie!!!) Am I able to mount ESLs on the wall - in the same fashion as a picture? I plan to have them either side of my fire place - but there is no room on the floor!
2) I'm also jumpy about touching things I shouldn't! What is a sensible way to cover the front / back(?) stators? I thick acoustic foam as used on some normal loudspeakers OK? I assume this would keep out dust aswell?
3) Can I run my normal speaker cable to the ESLs if the electronics are in the ESL or do I need to beef them up a bit.
Finally...Mr Sanders seems to reason that no amount of power is enough for these things! I'm intending on making these things about 40cmx120cm (which should be about midrange). Are 140W monoblock amps (actually slightly higher due to rasied rail voltages - more like 160W) OK for this application?
Thanks very much for your help again!
Gaz
Gaz
>> Right against the walls is a lousy way to use ESLs. It will work, but don't expect hi-fi. ESLs like a lot of room behind them. It is a relatively easy thing to protect the speaker from the dog and vice-versa. Build a frame around the ESL panel that is a cm or two larger than the ESL is thick. attach dust covers to that frame, made from the same material you used for the diaphragms. These will keep hair and **** away from the drivers. Then cover with a chicken wire mesh (wire screen with big holes), then put a pretty piece of thin cloth over it. Make sure the dust covers are tight and have a little room to move. Wrinkles will make rattling noises on bass notes.
>>> see above.
>>> I don't know what your definition of "normal" is, but 12 ga zip cord is about as good as it gets (wait, I have to zip up my asbestos suit...).
>>> 140W is plenty, assuming you are using reasonable ststor thickness and bias voltage. I also agree that you can never have too much power available. I run my ESL 63s on 200W/ch normally. Recently I have hooked up an LM3886 amp I built (about 30W/ch)and they play loud and sound great.
Gaz
Flat panel ESLs are extremely directional. You probably won't want to sit them on the floor because of the problems involved in aiming them at your ears. Think about stands that get the panels up to ear level when you are seated in your favorite chair. That way they'll be up where you need them for best sound, and out of the way of the dog's tail and wee wee.
MR
MR
Thanks for your reply Mark. I've been looking at your website and I'm sourcing the parts for your 'safer' bias supply. Finding parts in the UK is difficult but there is a place is Germany (hivolt.de) that does them. I've asked for a quote for the G-40.
I went to the Audio Circuit yesterday because I like reading through texts about unusual speakers (such as ion tweeters). One of the circuits I went to was the Flat Panel circuit (now closed). Can anyone tell me how they differ / work. Are they safer than ESL? Easier to build? Sound as good? etc etc.
Just interested really.
Thanks,
Gaz
Thanks,
Gaz
Originally posted by Rarkov
1) I have a dog and I am a bit jumpy about the idea of his wagging tail hitting things it shouldn't! (He's a v. long haired English Collie!!!) Am I able to mount ESLs on the wall - in the same fashion as a picture? I plan to have them either side of my fire place - but there is no room on the floor! [/B]
It is possible to mount them on the wall but not against the wall. In order to work well ESL's need to have considerable breathing space behind them (something like 1m would be nice)
2) I'm also jumpy about touching things I shouldn't! What is a sensible way to cover the front / back(?) stators? I thick acoustic foam as used on some normal loudspeakers OK? I assume this would keep out dust aswell? [/B]
The stators should be well insulated to begin with (even Sanders says so these days). There is nothing to worry about then. If you use perforated metal it is best to have it powder coated. Alternatively you can make stators using insulated wire. It is a good idea though to use some cloth as cover to keep dust away and dampen the resonance frequency
3) Can I run my normal speaker cable to the ESLs if the electronics are in the ESL or do I need to beef them up a bit. [/B]
I use normal Cat5 speaker wire. Works a treat.
Finally...Mr Sanders seems to reason that no amount of power is enough for these things! I'm intending on making these things about 40cmx120cm (which should be about midrange). Are 140W monoblock amps (actually slightly higher due to rasied rail voltages - more like 160W) OK for this application? [/B]
It will be more than ample. It is much more important that the amp is stable into a low load. Esl’s tend to have very low impedance at high frequencies. It may be advisable to put a series resistor of 2 ohm to help the amp.
you're welcomeOriginally posted by Rarkov
Gaz [/B]
Rarkov said:Hi,
Thanks,
Gaz
Don't know much about them but I found this:
Barry Waldron provided the following information:
I have had the opportunity of spending two afternoons with these speakers on two different occasions over the course of a year. The second pair of speakers were about five generations newer than the first pair.
I have also spoken with the designer, Klaus Zimmerman, and met him at the first session. He purchased several matching transformers from me.
"The company propaganda states that these are not electrostatic loudspeakers, however, in the broad sense, they are. The main difference is that the diaphragm is a self sealing electret element that does not get its HV charge externally. Otherwise, the speaker is comprised of two stators that act upon a diaphragm in push pull fashion by modulating a HV audio signal, just like an ESL. "
Barry Waldron
Rarkov said:I went to the Audio Circuit yesterday because I like reading through texts about unusual speakers (such as ion tweeters). One of the circuits I went to was the Flat Panel circuit (now closed). Can anyone tell me how they differ / work. Are they safer than ESL? Easier to build? Sound as good? etc etc.
There are different ways to make flat panels. ESL are one way, ribbons (like Apogees) are another, and coils glued to flm like Magnepans is another way. The last two use magnets arranged on the surface of a perforated metal sheet to provide the "bias" for the speaker. The Apogee type ribbons use a metallic conductor arranged in a serpentine fashion on the surface of a plastic film. The audio signal goes through the metallic conductor creating a magnetic field that interacts with the one set up by the stationary magnets and the result is sound. The magnepan type glue coils of wire to a plastic film and wirk pretty much the same way.
Both are "safer" than ESLs because there is no high voltage involved. I suspect they may be at least as difficult to build as ESLs, though the electronics is much simpler because there is no HV bias supply, and no step-up transformer (though they may require a step down transformer, depending upon the geometry involved).
NOTHING sounds better than an electrostatic speaker, except maybe the original source. That's just my opinion, of course, but once you listen to some ESLs, you'll understand why so many speakers compare their performance to electrostatics.
MR
MR, You'r 100% right!
Thats why I use ESL's myself!
I'v made my own ESL's a clone of the Final 1.4 but not so tall.
Audiofanatic
Audiofanatic
NO! Do not use wood. Wood is not a good insulator.
Use almost any sort of plastic you can get. PVC is an excellent insulator and is sold in sheets, but some adhesives won't stick to it. PCB material (fiberglass) is a good insulator, and easy to glue, but difficult and hazardous to cut.
I made a set of speakers using PVC insulators. I bolted the stators to the PVC using nylon bolts. Works great, and the bolts force the holes in the stator sheets to line up for maximum visual transparency (unimportant if the drivers will be behind cloth).
Finding compatible materials and adhesives are the biggest problems you have to solve when making ESLs. Everything else is pretty easy.
MR
MR
Just to keep everything in one thread:
There seems to be alot of problems using glue to hold the diaphram and stators on to the spacers, due to irregularities. Now, at first glance this may well sound stupid, but is it possible to use double sided sticky tape? I would be able to tightly control the D/S spacing. I would then use alot of nylon nuts / bolts to hold the whole thing together... So the build up would be as follows:
Stator : Tape : Spacer : Tape : Diaphram : Tape : Spacer : Tape : Stator
All held together with alot of nylon bolts, every 50mm or so.
How does that sound / what are the problems related to this method?
Thanks,
Gaz
Thanks,
Gaz
- General Interest
- Everything Else
- Q: DuPont Mylar Film for ESLs...
