| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I would like to build an AC power outlet that would be switched from the 12V trigger of my preamp/processor. I am not an engineer in any way, but after reading and searching for a while I thought using an optocoupled triac would be a good solution with low parts count.
But... the optocoupled triacs can't handle much current, so it really has to control another bigger triac, but for some reason I don't like the idea of triacs handling big loads. Then I thought of controlling an AC controlled relay instead. If this design would work I could get away with three parts (including the relay) to get it to work. And I could also control a really big relay if I want to and still only draw something like 10mA of the control signal. The big question, would this design work at all (as I said, I don't know what I am doing, this circuit is more or less a guess)? Thanks! Robert |
#2 |
SSR-solid state relay is readily available, however continuous dc will be needed to keep it on.
Gajanan Phadte |
#3 |
Thanks for your answer, but the whole idea is to keep parts at minimum and not having to use any external transformer.
Anyone else, would this circuit work? Regards Robert |
#4 |
does the Triac datasheet give a glue?
regards Andrew T. |
#5 |
U don't need an external transformer for the SSR. It just replaces what u have drawn and has zero crossover firing.
your ckt then becomes two components i.e. if u want to use the relay otherwise one. |
#6 |
what is the part number of the opto isolator triac?
Gajanan Phadte |
#7 |
Oh, thanks for all your replies!
I don't have a specific part number yet, if I decide to go ahead I would look at these: RapidElectronics Any comment is of course appreciated Regards Robert |
#8 |
That is an optoisolated triac driver and cannot drive a relay directly.
It is a solid state substitute of a gate driver pulse transformer I would still suggest u to google for 'ssr' and get some basics. Gajanan Phadte -----------------____________---------__--_--_-_-_ I find I have poor convincing power, good I am not selling anything |
#9 |
An optoisolated triac is a solid state relay. If you have no experience building with high voltage, choose the (pre-packaged) SSR. It might even be cheaper, certainly if you include the cost of your time.
If you look up datasheets and application notes on the optoisolators you'll find enough information to build one. My reference was the Motorola handbook from several years ago. There's nothing wrong with triacs handling big loads. |
#10 |
ssr triggers at zero croosover point. Not sure about optoisolated triac.
Zero crossover triggering is necessary to reduce RFI. Gajanan Phadte |
| horn outlet direction ? | ljk11 | Subwoofers | 2 | 24th June 2009 11:32 PM |
| M/S outlet (AC) | bibster | Parts | 3 | 24th January 2008 10:47 AM |
| 12v UPS relays Trigger, 1 ~ 11v no trigger | jacquesl | Power Supplies | 5 | 28th August 2007 06:30 PM |
| NewarkInOne Ebay Outlet | BrianDonegan | Parts | 0 | 28th May 2005 01:23 PM |
| Outlet to transformer switch for GC... | mcelaj | Chip Amps | 2 | 16th December 2003 11:37 AM |
| Page generated in 0.10622 seconds (76.30% PHP - 23.70% MySQL) with 11 queries |
