Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Routing aluminium?
Routing aluminium?
Old 26th November 2007, 01:51 AM   #31
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Routing aluminium? Send a message via AIM to Peter Daniel
Originally posted by poynton
In a similar vein, can perspex / plexiglass be routed with a 'normal' domestic router ?
I did 2" acrylic with a regular router and it was no problem (I did 1" at a time)
I find it to work best when router is attached to a table, the workpiece being rotated on a center set by a drill bit run through the table and workpiece (which sets the proper radius).
To order kits contact me through forum mail.
Old 26th November 2007, 01:59 AM   #32
The bottom cut out in the assembly pictured below was initially done with a jigsaw (1/4 aluminum) and later smoothed out with a router run on a template (so very little aluminum needed to be removed). Again, the router was mounted to a table, template attached on the inside.
Old 26th November 2007, 02:33 AM   #33
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Originally posted by Peter Daniel
...was initially done with a jigsaw (1/4 aluminum) and later smoothed out with a router run on a template (so very little aluminum needed to be removed).
I used that same method on a gaming computer I did a few years ago (previous obsession, before this one). It is 1/4" aluminum that I rough cut with a jigsaw and trimmed smooth with the router.
Old 26th November 2007, 06:15 PM   #34
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by poobah
The corners of the bit are prime culprits when it comes to "biting off..."
Nice to see you here, but what's "biting off"? I need to cut a 3mm rebate.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 26th November 2007, 06:23 PM   #35
poobah is offline poobah  United States
poobah's Avatar
"Biting off more than it can chew"... the problem being that if the bit is loaded the least bit too much... the router wants to jump out of the material, fixture, etc...
By rebate I assume you mean what we call a rabbit... a blind groove in the material?
Either way... I would still try to go it in one pass
Old 26th November 2007, 06:38 PM   #36
EC8010's Avatar
Not quite blind. It's to allow the mounting flange of the Jordan JX92S to sit flush with the front of the baffle, so there will be room for the swarf to clear into the mounting hole.
Old 26th November 2007, 07:04 PM   #37
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Routing aluminium?
Hey Poobah, nice to see you come up for air.
A rabbet and rebate are similar joints but I'd like to add the word recess in just for fun because I think that's what EC is talking about.
planet10 needs your help:
Let's help Ruth and Dave
Old 26th November 2007, 07:30 PM   #38
EC8010's Avatar
Default The only rabbits I've seen lately had mixamatosis
I'm certainly not talking about joints, I want to submerge the JX92S to make it flush. Talk about divided by a common language!
Old 26th November 2007, 07:32 PM   #39
mpmarino is offline mpmarino  United States
mpmarino's Avatar
Isn't it rabbet?
oh man......
Edit: Submerge to make it flush?
Now there's an image!
Crazy Yankee.
Old 26th November 2007, 07:32 PM   #40
poobah's Avatar
OK... I got it
Hey Cal... is that your swarthy image we are being blessed with?
Tell me Weldon is Irish?
Routing aluminium?Hide this!Advertise here!
PCB routing for audioamps SM2GXN Solid State 38 4th May 2012 04:28 AM
PCB Routing Mark245 Parts 15 27th May 2009 07:54 PM
CNC Routing Big Fun Horn atilsley Full Range 14 14th September 2008 10:29 PM
Routing signal yngwie Analog Line Level 0 17th June 2007 02:45 AM
MDF cnc routing dhole Multi-Way 1 21st January 2006 04:38 PM
