Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Compressor problems
Compressor problems
Old 12th November 2007, 11:44 PM   #1
boris333 is offline boris333  Canada
boris333's Avatar
Default Compressor problems
my compressor only builds up pressure up to 90 psi , how do i increse it to 150psi as it says on it that can run this high, the gague on it says 200 psi max , there is a nob that i can turn but only decreases the pressure , why does it stop pumping at 90 psi whats wrong with it ? where is the main valve that tells the compressor when to turn off ?
Old 15th November 2007, 01:18 AM   #2
dangus is offline dangus  Canada
Compressor problems
There will be a pressure switch in between the line cord and the motor; it will be connected to the tank or an air line. There should be a screw or nut to adjust the pressure setting. If this is one of those cheap oilless compressors, it may be hidden under a cover along with motor/pump assembly.
Old 15th November 2007, 06:46 AM   #3
suvatn is offline suvatn  Thailand
Yes, there will be a pressure switch in some where, pipe, compressor or air tank which you can adjust screw or spring.
Other things you should consider for more presure, maximum limited of tank, safety valve, the flex line cord.
Compressor problemsHide this!Advertise here!
Simple compressor PeteMcK Elektor 4 25th August 2009 02:30 AM
Mic compressor limiter fjpompeo Analog Line Level 0 1st June 2007 11:26 PM
Compressor diy XXLPeanut Instruments and Amps 5 14th June 2006 11:55 PM
making an ssl compressor or eq joeybancroft Instruments and Amps 2 29th February 2004 03:50 PM
compressor schematic JBL Solid State 18 22nd October 2002 12:00 AM
