Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 11th March 2008, 08:17 PM   #61
myhrrhleine's Avatar
Hi
HF hearing rolloff is not a brick wall. There is the ability to perceive above 20K.
I did a sin-sq test.
15khz sin and sq waves.
there was an audible difference to most test subjects.
That means 45k minimum hearing range.
Just because you can't hear it doesn't mean no one can.
Old 12th March 2008, 04:25 AM   #62
jcx is offline jcx  United States
did you carefully measure amplitudes and calculate fundamental component amplitude and match them?
sq wave has 4/pi fundamental - so sine peak amplitude would have to be adusted to that level to match - amplitude differences of 1 dB are readily detected, 0.1 dB matching is the usual requirement for valid abx
Originally posted by jcx
but people often make the mistake of thinking they can just push the button on their function generator to do the switching - and then they do hear a diff between them
in fact the amplitude of the sine wave fundamental of the tri and sq waves is not simply the peak values of those waveforms
you must correctly adjust the amplitude of the the sine ref in a ab/x test to the value of the fundamental component in the test waveform before going off half cocked and crowing about your >25KHz ultrasonic hearing
Old 12th March 2008, 05:27 PM   #63
I balanced everything with a HP FFT analyser (don't remember the model) and B&K mike.
Ribbon tweeter used was good to over 100k
Sensitivity of human hearing retroman Multi-Way 49 7th July 2009 10:31 PM
Distortion of human hearing PMA Everything Else 44 22nd April 2008 11:21 PM
Human Hearing................. Gavinator68 Everything Else 25 26th January 2006 02:15 AM
"The power of hearing" - Physics World May 2002 x-pro Everything Else 6 11th March 2004 08:55 PM
human hearing sss Solid State 123 8th September 2003 07:57 PM
Page generated in 0.07746 seconds (71.87% PHP - 28.13% MySQL) with 11 queries
