| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Just thinking about how to set up wireless rear speakers.
Is there a simply/cheap way to send audio over the mains circuit. I could then build 2 separate active rear speakers. I would want 2 channels, and each speaker to be fully independent. ( I have a mains socket in each of my rear corners) Dare I say it, the quality does not need to be great, it's only movie sound effects after all. |
#2 |
Did it Himself
You would only be able to send a mono signal. Also it's now illegal to knowingly superimpose signals or interference on the mains. Well maybe not illegal but not inline with CE regulations.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Or buy the two channels of wireless needed.
Try doing it with CAT5 in the wall = wired.
regards Andrew T. |
#4 |
I could accept mono, and CE regs don't effect me, so I'm not put off yet.
On the CE thing, I thought you can buy LAN over mains set-ups. |
#5 | |
I suppose the cheapest solution I've got so far is to buy 2x 'video senders' at about £30 each. |
#6 |
Ok, so now i've found an FM transmitter for £5, so I just need 2x cheap FM receivers.
#7 |
Did it Himself
You are still going to need a mains lead to the the speakers if they are wireless. Why not just use thin figure-8 or flat cable and put it under the carpet?
#8 |
That's what I've got at the moment, but new carpets are being fitted soon and I was thinking it would be nice to avoid having to install the wires under the carpet.
But it was a bad idea, especially to end up with an inferior and more complicated system. |
#9 |
Radio Shack Accurian amp - the receiver/25 W amp is still available at a few stores for $15
I don't know if the "HomePlug" transmitter can be found anywhere though |
#10 |
that's so cheap, but maybe it was a bit more expensive before the transmitters sold out
| Linear power supply causing mains hum at speaker | cmhadley | Power Supplies | 5 | 18th April 2009 03:43 PM |
| Dedicated mains supply - what fuse? | Nuuk | Everything Else | 15 | 16th March 2007 05:13 PM |
| Converting this power supply to 127VAC (not the mains) | -_nando-_ | Power Supplies | 6 | 31st May 2006 05:48 PM |
| Do I need to isolate the mains for switching power supply and traditional transformer | Aaron323 | Power Supplies | 8 | 5th January 2006 10:46 AM |
| Late night listening (aka your mains supply) | ALW | Solid State | 54 | 14th October 2002 04:09 PM |
| Page generated in 0.10673 seconds (76.42% PHP - 23.58% MySQL) with 10 queries |
