Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Super-Duper-Uber Capacitors On The Way!!
Old 7th November 2007, 01:11 PM   #11
auplater is offline auplater  United States
auplater's Avatar
Default mega-joules... and more!
My thoughts as well...
think about the "crowbar on a car battery" scenario..
I can imagine exploding carbon nanotubes scattering debris
"They also dismiss the several thousand amp currents that it would take to charge the thing in the claimed time as "no problem"."
Having dealt with thousands of amps (in chromium and nickel plating, electropolishing, etc.) I can assure you, it's anything but "no problem"... sounds like researchers looking for follow up funding rather than competent enigineers developing practical applications. Think 350 x 10^5 amp-seconds to determine reasonable recharge rates... not to mention the particulars of distributing this charge into the capacitor uniformly and repeatedly... not a trivial pursuit
John L.
"I've forgotten more than I care to remember" The Last Conspirators
Old 7th November 2007, 11:29 PM   #12
ak_47_boy is offline ak_47_boy  Canada
Imagine the almost instantaneous discharge of a car battery into a laser!
Old 8th November 2007, 01:06 AM   #13
JohnG is offline JohnG  United States
All double-layer caps that I'm aware of achieve higher voltages via series combinations of caps. The voltage limitation on a single cap is there to prevent an electrochemical reaction from starting. They say a higher voltage due to nanotubes, but not how much higher. This probably means they are purely speculating, or it is not substantially higher.
I'm not dissing the technology, which, if it pans out and the cost is reasonable, it likely to be very useful in energy storage applications. I think it's unlikely that it will be much good for audio. Just my own speculation, though.
John
Old 8th November 2007, 01:40 AM   #14
valveitude is offline valveitude  United States
valveitude's Avatar
If they have comparable ESL/ESR, and voltage limitations, to the current ultra-caps, I would tend to agree...but...if a cap with a couple dozen Farads at around 12V or so surfaces at a reasonable cost I can see some uses. First thing that comes to mind is a filament/bias supply that charges while the amp is "off", then disconnects from the line while playing. Ditto that for the B+ if the voltage capacity is available (pre-regulator of course).
Of course, as you've said, this is all speculation until we see something tangible. It is exciting to see the new nano technologies starting to take off though.
Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
Old 8th November 2007, 02:13 AM   #15
If not ultracaps, a promising battery technology is Li-Fe phosphate, such as that made by A123 . Energy density is probably a lot higher than an ultracap can reach, and they are available today. You can find them in high-end DeWalt cordless tools, and I've seen them for sale by R/C hobby companies.
Not cheap, though.
John
Old 8th November 2007, 01:28 PM   #16
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
John
I lost track of the patent they were waving around, but these folks were definately fishing for money. Their spin was that electric cars won't catch on until you can "fill 'er up" in about the same time as a tank of gas.
Another non-trivial problem is the swiching regulator you need to deliver constant voltage as you discharge the capacitor.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 25th February 2013, 08:30 PM   #17
gootee is offline gootee  United States
Default Make your own micro super-capacitors, at home?
What about this?!
Researchers develop new technique to scale up production of graphene micro-supercapacitors
They say you can MAKE YOUR OWN graphene micro-super-capacitors AT HOME, with a DVD-labeling system!
Super-Duper-Uber Capacitors On The Way!!Hide this!Advertise here!
Super capacitors sivan_and Everything Else 17 24th April 2006 03:29 PM
Nichicon Super Through Audiophile Capacitors for sale ccozgo42 Swap Meet 0 25th January 2004 04:43 PM
super duper newbie questions M5150 Multi-Way 13 9th February 2002 02:47 AM
Copyright ©1999-2017 diyAudio
