diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Enclosures the easy way (http://www.diyaudio.com/forums/everything-else/111400-enclosures-easy-way.html)
Sparky OR 6th November 2007 01:05 AM
I found at the local recycle stores, a good source for enclosures for preamps or small amps. The are satellite receivers. I picked up a Drake and a Senseni. Highly adaptable, with RCA jacks, 75 ohm connector, power cord, fuse and +/- 15VDC, 12VDC and 5VDC regulated PS. I'm reusing the power supplies and regulators to house a Hagerman Bugle phono preamp and as well as low gain preamp circuit for CD and Tuner.
Will post photos later. BTW the enclosures vary, some all aluminum and some with steel cabinets.
Cheers!!
Copyright 1999-2017 diyAudio
