| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hey all,
well, after calling around Toronto to see how much it would cost to get a couple heatsinks and the front piece of AL plate anodized (+200$!!!) I am thinking to try it out myself. There seems to be a plethora of information out there and it looks like a good project to try out. If anyone in the GTA is interested in getting something anodized (and helping out) let me know. Mantisory |
#2 |
bump
#3 |
Hello Mantisory
Have you looked at www.caswellcanada.ca they have all the diy anodizing and plating supplies and info. Goodluck BD
"Leave it alone, it sounds fine." -My wife- |
#4 |
yeah, that stuff is even more expensive (their kits i mean).
I have found someone to lend me a rectifier (12V/10A), and i am picking up battery acid today...so now i just need to get some dyes and some buckets to do it in and i am ready to go... |
#5 |
I look forward to progress reports.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#6 |
Not too difficult... try to get "clean" battery acid (not brown dirty looking stuff) or it may not take the dye ...
Typical conditions 15% H2SO4, 20 asf ~ 20 minutes or so... run as constant current (let the voltage increase holding current constant)... can be done AC or DC (anodic(+) if DC) 12 volt supply may not be high enough voltage to get a decent thickness... more typically 24 - 36v for decent film growth, if I recall What color(s) are you looking for? also, the dyeing usually is done hot, and needs a sealer (boiling water acidified with acetic acid) to seal up the pores. Disclaimer: This is an informational only post, not intended for production and or processing of any hardware or parts. JJohn L.
"...His brain is squirming like a toad..." Jim Morrison |
#7 |
I am not sure what color i want yet...i have heard that a real good dark black is difficult to obtain....i may try using a resist so i can do multiple layers...we'll see about that once i have done some experimenting.
15% H2SO4 - i am not sure what the battery acid strength is (I am getting 5 gallons new from NAPA) - what is 20asf mean? the power supply i have is 12V DC...I had bought a computer PS for the purpose, but someone on audiocircle in TO has generously offered to lend me his 'vigor electro-plater'.... from what i have read, the sealing can be done just with boiling water, no? The 'sealant' is necessary mostly if you want to have a better protection from scratches, etc? will post progress pix once i start b |
#8 |
20asf = 20 amps / square foot... 12 volts probably will be difficult to get enough thickness to take the dye well...
vigor plating supply... not enough voltage... plating is totally different from anodizing... u can use 2 car batteries in series to get 24 volts... use light bulbs or other means to control current Dark colors are tough w/o special treatments, especially with type II coatings... Sealing with acidified DI boiling water helps to "set" the dye and keep it from leaching... good luck!! Disclaimer: This is an informational only post, not intended for production and or processing of any hardware or parts. John L.
#9 |
okay...I am going to give it a try anyway and see how it goes...I am not sure about the connecting car batteries together...ugh -this 'experiment' is dangerous enough already
B |
#10 |
| Anodizing Question | N1ESE | Everything Else | 5 | 18th November 2008 12:58 AM |
| anodizing | nyman | Everything Else | 2 | 8th March 2005 09:51 PM |
| Anodizing tips please ... | 13DoW | Pass Labs | 5 | 30th November 2004 01:19 PM |
| DIY Anodizing | Andrew Steele | Everything Else | 11 | 30th May 2002 09:49 PM |
| Anodizing | doktor | Everything Else | 7 | 16th April 2001 08:05 PM |
| Page generated in 0.10925 seconds (77.55% PHP - 22.45% MySQL) with 10 queries |
