Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd October 2007, 04:08 PM   #1
JRace is offline JRace  Canada
Default HUMM from subamp - only when Laptop plugged in...
I am using a class D BK1000 amplifier to drive a tube shiva sub.
I have a lptop in my audio chain and whenever it is plugged into AC there is a very audible anoying HUMMMM from the sub amp.
The sound goes away only if I do one of the following:
Disconect the AC power to the laptop,
or
Disconect the vga out from either the projector end or the laptop end.
Any ideas?
The hum is present even without CATV connected.
My signal chain is:
Laptop:
- VGA to projector
- Optical SPDIF to receiver (tried onboard optical SPDIF, onboard analog , outboard usb optical and coax)
Receiver out o sub:
- LFE/Sub 100Hz to BK1000 subwoofer amplifier via analog RCA
Thanks for any help....
Old 23rd October 2007, 12:15 AM   #2
Update:
The unwanted HUM is gone when I remove the 35' DVI-HDMI cable from the signal chain (either at the DVD or the Proj).
When I turn off the laptop screen the HUM is gone.
When I reduce the brightness the hum is worse....
Seems like noise is being introduced with the laptop that is coming back through the DVI and into the sub amp....
Old 23rd October 2007, 02:01 AM   #3
This is a common problem. Try making sure that the lap top and the projector and any other items do no share the same circuit.
Try a cheater 3 to 2 plug on the lap top.
Old 13th November 2007, 04:01 PM   #4
It's called a hum loop. Simple fix - You are probably using an extension lead/plug block?. If so, don't. Plug them into a different plug socket and the problem should just vanish. I think it's sometihng to do with earthing...
B&W ASW-4000 Subamp ManUtd Solid State 9 3rd May 2012 09:17 AM
bridge or parrallel subamp help HIPCHECK Chip Amps 5 13th October 2006 10:00 PM
jast finished diy n-ch car subamp tmyr Car Audio 23 23rd August 2006 07:39 AM
What is the simplest way, to convert this GC to a subamp? Franz G Chip Amps 10 3rd November 2004 07:07 PM
Car subamp 50W on 12v palesha Solid State 11 14th July 2002 12:35 AM
Page generated in 0.07558 seconds (73.40% PHP - 26.60% MySQL) with 10 queries
