Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd October 2007, 03:08 AM   #1
Default panasonic electret mic amplification question
got the mics, got a maudio transit, from what i read it says it supplies 5v of power for electret mics. got it plugged in and i dont get anything, am i doing somthing wrong? do these mics not work with the power supplied from the transit.
Old 22nd October 2007, 05:21 PM   #2
Iain McNeill's Avatar
The web site specs say it accepts "self=powered" mics and refers to the input as a line in.
Didn't see anything about an electret supply. You may need to add your own. Quite easy really: 2 x AA cells, a 2 to 5Kohm resistor and a 2.2uF cap. The mic will work with either polarity but the correct polarity will give lower distortion. Put the +ve of the cap to the mic-resistor connection, -ve to line in.
Old 22nd October 2007, 06:23 PM   #3
thank you for your reply. its in the manual where it states it supplies power.
i think i have it working at the moment, but i might just build the simple power supply because the volume is quite low when recording.
Old 24th October 2007, 04:42 PM   #4
Pjotr's Avatar
Hmm, the M-Audio Transit supplies 2.5V mic power to an electret mic. by default. At least mine does And any electret mic capsule works straight away with it.
But here is a schematic for a mic to power it externally. I made it for the IBF Akustik mic which also uses a Panasonic electret capsule and was calibrated at 2V and 2K2 load.
Cheers
Old 24th October 2007, 05:08 PM   #5
Pjotr's Avatar
Btw, this is what the manual says:
Electret microphone question zobsky Parts 23 14th May 2011 09:22 PM
Panasonic SA-XR55 bi-amp question JohnG Multi-Way 2 6th November 2006 11:08 PM
Question re: Dipole Sub amplification Arctophile Subwoofers 8 21st July 2005 05:18 AM
Orion Amplification Question ¿GotJazz? Multi-Way 23 17th March 2005 03:20 AM
High Quality mic amplifier for Panasonic WM-60a electret? Toster Solid State 8 10th March 2004 06:29 PM
Page generated in 0.09211 seconds (76.95% PHP - 23.05% MySQL) with 11 queries
