| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I recently built a volume pot with shunt resistor in a box. I then tried ot add a bleeder cap (200pf) and 75 ohm resistor to ground as suggested in a thread here. I found it removed some of the overall transparency. What would the purpose of adding a cap/resistor to input to ground other than rolling off the top frequencies?
Thanks, |
#2 |
Did it Himself
Got a link to the thread you mean? Seems a barmy idea if it's as you describe. Can't see what it could be bleeding either, other than the high frequencies down the drain.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
The 200pf cap and resistor will drain RF interference on the signal wire to ground.
Personally I'd do this at power amp chip input pin but this will depend on whether you have built your own amp :-) |
#4 |
I tried it both with a 100K Alps pot, 10 shunt resistor, and 200pf/75 ohm resistor on the input to ground. Personally I find the bleeder doesn't just take the rf out, but it seems to bleed out some of the top end. Maybe I'm mistaking the rf noise as top end frequency.
| Bleeder resistor! | lanchile | Chip Amps | 15 | 24th February 2009 10:06 PM |
| Bleeder Resistors | ptah | Power Supplies | 43 | 13th March 2008 06:11 AM |
| Resistive Bleeder Question | Randy Knutson | Power Supplies | 6 | 17th February 2005 09:08 PM |
| Page generated in 0.06423 seconds (75.04% PHP - 24.96% MySQL) with 10 queries |
