| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Has anyone successfully installed SIMetrix Intro onto a pc running Vista?
I have been using SIMetrix for a number of years and have just replaced my pc with one that has Vista Business on it. I have installed Intro v4.5 (which I prefer) and the latest v5.3 onto the new pc and find that in both cases the grid does not display correctly in the schematic window. There are 22 columns of dots followed by a similar number of blank columns then a further 22 columns of dots then another series of blank columns and this continues across the full width of the screen. I am using a 19" WS monitor with the resolution set to the recommended (native) 1440 x 900 and the alternating dotted and blank sections persist at different levels of magnification within the schematic window. The 'snap to grid' still works in the blank sections but obviously without the dots to identify the grid positions accurate component placement becomes difficult. Catena have not come across this problem before but suspect that it is display driver related since the two versions use completely different underlying graphics subsystems. Having checked, I am using the latest driver for both the monitor and the graphics controller (Intel 946GZ chipset). Any suggestions as to how to resolve this problem would be gratefully received. Geoff |
#2 |
Ditch Vista.
#3 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Thanks for the suggestions. I too would have preferred to avoid Vista but unfortunately it was not an option in this case.
#5 | |
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#6 | |
frugal-phile(tm)
dave
#7 | |
As a moderator you should know better than to hijack threads. If you want to ask questions like this please move the off topic posts to a new thread. Geoff |
#8 |
frugal-phile(tm)
Just following the conversation.... and not off topic if one considers the real question to be "problems with Vista"
In every instance i've run into with issues like this on Windows is that the user -- after considerable frustration with getting it to work on Vista has had to go back to XP. If you can't get XP on the new computer you got, i would take it back and get a refund or swap for one that will run XP. dave
#9 |
if the laptop is running vista buisness then u can legaly install xp pro. the licence is down gradable.
#10 | |
| SIMetrix questions... | bogdan_borko | Solid State | 3 | 27th May 2006 09:39 AM |
| Output transformer in SIMetrix? | argo | Tubes / Valves | 3 | 18th January 2005 08:34 AM |
| SIMetrix Intro for Linux | Geoff | Everything Else | 0 | 25th September 2004 10:13 AM |
| 'Vista' | ShinOBIWAN | Multi-Way | 21 | 22nd April 2004 08:46 PM |
| Hol to multiply/add/subustract curves in simetrix? | Bricolo | Everything Else | 0 | 10th June 2003 03:40 PM |
| Page generated in 0.10912 seconds (82.52% PHP - 17.48% MySQL) with 10 queries |
