Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
The loudness war....
Old 23rd September 2007, 03:06 AM   #11
mpmarino is offline mpmarino  United States
mpmarino's Avatar
I did the same thing. I found the cd unlistenable at home (it's great on my factory car stereo) so I got the LP hoping for a revelation. It's such a good album it's worth trying to get good sound.
Unfortunately on an a/b comparison they sound the same to me - maybe you will be happier. please report back.
I've been watching a lot of Rush DVDs. R30 in particular sounds better than most of the studio albums IMHO. Is it possible to strip the audio and make a CD??
edit:http://www.glump.net/dokuwiki/howto/..._ripping_guide
Crazy Yankee.
Old 23rd September 2007, 03:19 AM   #12
tade is offline tade  United States
Send a message via AIM to tade
Nice player daveis!
Old 23rd September 2007, 04:28 AM   #13
Daveis is offline Daveis  United States
Tade, somehow yours looks better than mine...
What do you use for a preamp?
Ok, switching to vinyl for vintage music may not solve all the problems...
And mint records suitable for 24/96 conversion are probably getting more and more rare.
I've seen a few re-pressings though of classic rock.
Old 23rd September 2007, 03:49 PM   #14
mrwhy is offline mrwhy  United Kingdom
Originally posted by Daveis
I am looking for a turntable right now.
As I listen to much 60's and 70's music... my plan is to make my own 24/96 recordings from mint vinyl.
I have a DVD-A made from a quadraphonic Dark Side of the Moon disc. It's actually quite close in quality to the commercial SACD made from another set of tapes.
The difference in volume between CD's made in the 80's and today is amazing.
And it makes me cry that bands that should know better (eg. Rush) allowed their albums to be mastered overly loud.
Hi Daveis and fellow discophiles
Have you tried listening to the output from your phonographs with the pickup resting on a stationary record and while music is playing in the room!
It reminds me of my Son's main Fender Amp that sounds so "alive!". The reason is 6 6L6 output valves mounted all-a-jangle 4 inches from 200 watt speakers!
He swears by it and the hi-fi amp I have built for him is "not right".
I expect what you criticise about modern cds is the dynamic range, which cuts the live transient peaks because "sounds louder" sells better (especially to those who have already damaged their hearing).
Old 23rd September 2007, 05:03 PM   #15
A thread on Hydrogenaudio did a comparison of the Red Hot Chili Peppers latest album Stadium Arcadium. Its available on vinyl and CD. The CD mastering was notorious for overly compressed bad sound. The LP sounds quite natural.
There's a set of comparisons of the CD and LP versions. Sadly, the comparison uses 124kb MP3's to make its point. Well 128kb and less MP3's sound bad to begin with so its hard to hear the difference.
But even with the low bitrate MP3 what comes across is that drums are completely messed up by compression. The other thing is that the LP mix sounds relaxed and easy on the ears. I will admit that when I first heard the CD version it sounded ok to me. I had to switch back and forth about 3 times before the CD version started to sound annoying and the LP version was preferred.
I suspect these musicians don't cry foul because their hearing is so damaged after playing loud shows they can't hear how bad their mix is.
Now WHY do they compress music for the radio? Can't the radio engineers compress the music before broadcast? Can't my car stereo have a built-in compressor? Then when I'm at home I listen to good music?
The usual explanation that they did it so it sounds loud on radio in the car doesn't doesn't make any sense. How hard is it for the radio stations to use their own compressor/loudness booster?
Old 24th September 2007, 03:43 AM   #16
Why do radio stations and everyone else always compress? It must be a question of signal to noise ratio.
The dynamic range of hearing is 120 db or so but most means of getting the music to us find it hard to better 60 db. The ultimate lower limit is thermal noise, acoustic noise during the recording and intermodulation distortion in the microphones.
The dynamic range of an orchestra, live, is around 80 db assuming a VERY quiet audience and 100 db peak orchestral level (120 db is threshold of pain)
In your listening room at home the ambient noise is unlikely to be less than 35 db (even if you live in the unspoiled countryside)
so even with an at-home dynamic volume expander (lots of problems) at a preferred listening level of 80 db (very loud) you could experience only a 45 db dynamic range.
For an orchestra playing at peak 100 db level you could only thern hear 30 Hz to 20KHz and at 70 db 70 hz to 16 KHz. Even at the ear's most sensitive frequency the dynamic range woud be 50 db
Old 24th September 2007, 06:34 PM   #17
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
there's no sense in this....
I always see manufacturers bragging their CD player does 120db SNR, they make really good digital gear for recording studios and then the "technicians" and producers go and mess it up while recording.
before all this, I wondered, why do most people concerned with hifi want vinyl while CD is "technically" superior....now I know why.
Old 25th September 2007, 01:02 AM   #18
I have two discs. One is a DVD-A made from quadraphonic vinyl recording of Pink Floyd's Dark Side of the Moon. The other a recently made SACD.
The SACD should be much better, but it isnt. That kind of proves to me that good vinyl was equal to SACD. Think about that. Vinyl is as good as not just CD, but SACD.
Don't get me wrong. I don't want or think everyone should go back to vinyl discs.
And as I understand things, Rush's vinyl release of their recent album doesn't sound any better than the CD. Not that it technically should sound better. Just that there was the hope that either different people or a different mindset was used when the vinyl versions was mixed.
Old 25th September 2007, 06:29 AM   #19
[QUOTE]Originally posted by djQUAN
[B]there's no sense in this....
The 120 db is a statement about the ratio of the loudest sound to softest sound reproducible.
But the sound AVAILABLE to record is:
Loudest Full orchestra 100 db
Softest 35 db of quiet country living room.
Ratio 65 db
To that we must also include:
Background noise (coughs, splutters, candy-wrappers, chat) of audience 45 db. So the concert-hall dynamic range is 55db
The TRANSIENT peaks of a live performance are typically 100 to 1000 times the average. So even if the engineers amplified the sound to 120 db peak transients (threshold of pain - ultimate non-linear clipping of your ears!) the dynamic range could only be 50 to 60 db.
In short the 120 db is nonsense - NEVER available!
John
Old 25th September 2007, 06:48 AM   #20
phase_accurate is offline phase_accurate
It is NOT hard for them actually, most of them DO it foir years !
So there is really no reason for compressed dynamics apart from those ones listening to their music in noisy environments whitout using any radio.
So we have to blame all those who are listening to their MP3 etc in buses, trains, subways ......
Charles
The loudness war....Hide this!Advertise here!
Loudness etc. of ESL panels jjbunn Planars & Exotics 10 13th November 2008 11:52 AM
How much loudness is enough for HT? Phil Olson Multi-Way 19 29th March 2008 12:14 AM
Loudness Switch thoronx Chip Amps 0 25th February 2008 06:49 AM
three tap loudness pot adason Parts 8 26th January 2006 08:53 AM
