Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 5th September 2007, 01:02 PM   #31
KP11520 is offline KP11520  United States
KP11520's Avatar
I like the wisdom in that paragraph!
At 47, I am hoping to catch up with some solid ideas but nothing replaces the experience so I need to do and learn so many thhings!
NO worries, I have lots of unused apace in my head! In fact, so much space, the "Defragmentation Utility" says Defragmenting is not necessary! (see below)
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Old 5th September 2007, 03:08 PM   #32
gootee is offline gootee  United States
Originally posted by AndrewT
I'm no chemist, but I think this statement is referring to the liquid phase of the soldering or tin plating process.
Some months ago J Neutron gave us a comprehensive review of what happens here.
Hi Andrew,
OK. But there are also apparently-serious potential problems when mating gold- and tin-plated metals in sockets. Intel had a white paper about it. You can search for something like "gold tin pin socket plated", at http://groups.google.com , and find lots of discussions about it. Apparently, certain motherboards using dissimilar metals (gold and tin in that case) in either SIMM sockets or CPU sockets started having major problems, within a matter of months in some cases.
From the little I have read about it, I think that the slight potential difference, plus a little moisture in the air, causes some kind of galvanic reaction, and corrosion or oxidation of the tin, at least, resulting in a much higher contact resistance.
Any two dissimilar metals, being in contact, can cause some kind of "corrosion" problem. How much of a problem it might become depends on the properties of the two metals. I'm not a chemist, either. But I did find and read some of the explanations, at one time, back when I was specifying all of the sockets and Molex connectors for my Curve Tracer product, and became concerned about it. At the time, I decided it would be safer to avoid mixing metal types in sockets, if possible.
- Tom Gootee
http://www.fullnet.com/~tomg/index.html
Old 5th September 2007, 03:44 PM   #33
Hi Tom,
thanks for clarifying that.
Corrosion between dissimilar metals will always happen.
Even slight composition differences between apparently similar alloys will generate that electrochemical voltage.
If all the chips are using solder coated (=tinned) pins then similar coated sockets would be better than choosing another metal.
If however tin plated pins are used then that equals a different requirement for the sockets.
regards Andrew T.
Old 10th September 2007, 03:06 AM   #34
KP11520's Avatar
Hi Everybody,
Just to let you know, if you also get to a point where you need to drill a PCB for whatever reason, I found this place to have quality bits at great prices and great service too: http://drillcity.stores.yahoo.net/sitemap1.html
Thanks to all of you who helped!
Regards//Keith
Old 12th September 2007, 12:28 AM   #35
Just melt the solder then blow it out of the hole with 100 psi from an air gun.
drilling pcbs impsick Chip Amps 70 12th November 2011 11:27 AM
Drilling Heatsinks wes-ninja250 Parts 7 29th September 2005 11:22 AM
TO-3 Drilling Jig BrianDonegan Solid State 10 16th February 2005 09:06 PM
Page generated in 0.08051 seconds (74.21% PHP - 25.79% MySQL) with 10 queries
