getting my laptop operational? getting my laptop operational? - Page 3 - diyAudio
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th August 2007, 01:16 PM   #21
mpmarino is offline mpmarino  United States
mpmarino's Avatar
the Local Area Connection says "network cable unplugged".
-indicating a connection issue. If your going right to the modem you'll prob need a crossover cable as OZmike said.
OH, MOST OF THE MODEMS I'VE RUN INTO CANNOT USE USB AND ETHERNET SIMULTANEOUSLY. ... I'm not shouting. I'm just trying to exemplify that you should have a modem with a working ethernet port so you can use a router...
Crazy Yankee.
Old 25th August 2007, 01:27 PM   #22
It's booted back up,
the wireless was disabled and the LAN was unplugged.
Clicked on wireless and it re-enabled itself.
If the DSL thingy (it's labelled "BT Voyager 205 ADSL Router") that I'm calling a router, describes itself as a two computer link to broadband and it also talks about a gaming link then I would expect it to take both these PCs to the ISP.
But I still don't know if the storm took out the ethernet link, either in the PC or in the DSL.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th August 2007, 01:33 PM   #23
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Well, that is a bit of a mislabeling. It is not a true router, but a DSL modem with some router-like features. The specs for the device say that you CAN use the ethernet and USB at the same time. You cannot do this with most cable modems that have both jacks.
Andrew, when there is an Ethernet cable plugged in from the laptop to the DSL modem, does is still say "network connection unplugged"?
Old 25th August 2007, 01:34 PM   #24
is post19 telling me that I can avoid the direct connection to the router and go from laptop to desktop to router to ISP?
This would get rid of the problem of a router fault.
But if the fault is in the desktop, I would need an alternative cable entry. USB? But will my win98 operating system on the desktop allow usb?
regards Andrew T.
Old 25th August 2007, 01:36 PM   #25
yes, "Network cable unplugged"
Did you go and look up the spec sheet?
regards Andrew T.
Old 25th August 2007, 01:40 PM   #26
Andrew, you can do what is called "ICS", Internet Connection Sharing.
Laptop ethernet ---> PC ethernet (via crossover cable) ---> PC USB ---> DSL Modem/Router.
I don't recommend this route for someone not familiar with this stuff, not to mention I don't think win98 supports it.
EDIT: If it still says network cable unplugged when it is in fact plugged in then either the cable or the modem/router is faulty.
Old 25th August 2007, 01:40 PM   #27
what if I connect the laptop to the desktop via the ethernet RJ45 cable?
I've just noticed that the ethernet cable has only two pins connected at each RJ45 plug.
I'll try to find another RJ45 cable.
I intend changing the desktop over to XP but only after I get the laptop working with all the software I need on it.
edit,
they're not RJ45. The spare RJ45 have 6pins.
These dsl plugs are 4pin with two of them blank.
regards Andrew T.
Old 25th August 2007, 01:46 PM   #28
An ethernet cable with only 2 pins? Well there's a problem.
http://www.voyager.bt.com/wired_rout...oduct_info.htm
http://www.voyager.bt.com/wired_rout...ifications.pdf
Old 25th August 2007, 01:46 PM   #29
cliffforrest is offline cliffforrest  United Kingdom
That is a modem cable, NOT ethernet.
An thernet cable has all 8 wires connected.
Old 25th August 2007, 01:51 PM   #30
Andrew, even if you find a good ethernet cable you will still want both PC's on ethernet and not one USB, one ethernet. To do this you will need at least an ethernet switch.
I have such a switch you can have for free; I'll even pay to ship it to you. It needs a power supply, but you are the king of supplies, so I'm sure that's no hurdle.
http://www.xpcgear.com/dldss5plus.html
getting my laptop operational?Hide this!Advertise here!
how to balance two operational amplifiers connected in parallel ? Mikewong Chip Amps 10 8th May 2008 11:11 AM
Dual Operational Amplifier Question? lindomar Class D 3 7th October 2007 08:09 PM
Is www.tolvan.com operational ? ashok Multi-Way 5 26th October 2006 03:47 AM
need a high voltage operational amplifier! xiaonan Chip Amps 6 7th September 2006 04:37 PM
How (Not) to Decouple High-Speed Operational Amplifiers Ruach Digital Source 24 17th October 2005 01:50 AM
Copyright ©1999-2017 diyAudio
