| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
so ive done a bit of searching and ive found that for the diy'er the best value is the panasonic mw-61a capsule, correct?
now, what i havent been able to find is a tutorial on how to build a mic using this part. furthermore, i would need it to be self powered, or build a cheap/simple power supply (i guess thats called phantom power) i have no problem using a design that uses a 9v battery. The only use i would have for this mic is RTA and MLS measurements with apps such as speakerworks of lsplab. since i will be trying to keep it on the cheap i would be using somthing like a m-audio transit since i wont need power from somthing like a m-audio mobilepre. if anyone can point me in the right direction, or if i should be posting in a different fourm, please let me know. thanks and i hope i dont get too many flames |
#2 |
Speakerholic
Hi, I have moved this over to everything else from loudspeakers.
#3 |
hi there,
The panasonics are nice mics. I use them a bit nowadays. Check out linkwitzlab.com, http://linkwitzlab.com/sys_test.htm#Mic it is what I have been using. This is pretty easy to breadboard and make a stereo mic. I've done some binaural recordings with them, and they impress everyone. Look into the yahoo mic builders group, they do a lot with this capsul, and diy microphones in general. Also check out http://homerecording.com/bbs/ they do more front end audio stuff. |
#4 |
dont need stereo at this point and dont think i will any time soon.
what about a preamp, is this the same as phantom power? |
#5 | |
A preamp simply buffers and amplifies the usually small signal coming from the microphone up to line level, and doesn't imply phantom power (which is probably not too useful for this application). |
#6 |
#7 |
so i now know what im doing about the mic
now is the question of the necessary equipment i will need after that. if i get a m-audio transit, then i need a pre amp if i get a m-audio mobile pre, then that covers both the interface and the preamp am i getting this right? is there any cheaper way to do what i am looking to do? |
#8 |
1) Byu the Panasonic WM-61A from Digikey or on Ebay.
2) Make a power supply: ![]() 3) Plug it into the mic input of your notebook PC, or use the M-Audio Transit (or similar) If you use the M-Audio Transit you may be able to omit the separate power supply since it has [I believe] built in power for electret microphones. 4) Make a suitable stand I just canibalized a cheap PC mic with a new capsule: ![]() SveinB. |
#9 |
Thanks for the post by the way, reminds me to put one or two of these guys on my next DK order. Would definitely be handy to have around since the cheapie computer mic I have now is absolutely horrible.
#10 |
so a preamp is not necessary?
or is a preamp prefered but the 9v power supply is good enough? |
| diy microphone pre-amp | sadim1223 | Parts | 11 | 13th March 2009 04:30 PM |
| Need microphone amp | borges | Analogue Source | 0 | 1st June 2005 10:52 AM |
| spy microphone | sss | Everything Else | 10 | 6th January 2005 11:00 AM |
| Microphone amp? | zmoz | Solid State | 3 | 19th June 2003 11:09 PM |
| Page generated in 0.09226 seconds (87.15% PHP - 12.85% MySQL) with 10 queries |
