diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Upgrading from celeron to p4 ? (http://www.diyaudio.com/forums/everything-else/107165-upgrading-celeron-p4.html)
woody 19th August 2007 07:17 PM
I have a Sony Vaio running a 1.7g celeron processor. I have
a 1.7g p4 processor. Would this be a plug and play upgrade
or would I need to change motherboard jumpers?
I_Forgot 19th August 2007 09:35 PM
Check the motherboard manual.
I_F
soongsc 20th August 2007 02:37 AM
Are they pin compatible?
neutron7 20th August 2007 05:12 AM
Get a program called CPU-Z (cpu-z has no spyware and it is free)
It will identify the CPU, pin package and motherboard.
Once you know what motherboard it is you can look up what CPUs it supports, most likely if it supports celeron 1.7 it probably support p4 1.7 from the same generation
woody 20th August 2007 10:34 AM
Thanks for all the help. I got the program subjested by Neutron7
and it realy worked great.
Copyright ©1999-2013 diyAudio
