Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 10th August 2007, 10:51 PM   #1
preiter is offline preiter  United States
preiter's Avatar
Default Sound card for loudspeaker measurement
I'm looking to set up a cheap setup for characterizing speakers using my computer.
The Behringer ECM8000 mic with the Behringer 802 mixer as a pre-amp/phantom power supply seems to be a popular combo.
My question concerns the sound card in my PC. Currently, I am using an integrated chip (RealTek ALC850). I am guessing that this is not ideal.
Anyone have any suggestion for a sound card (< $100 preferably) with high quality analog output and input?
Old 11th August 2007, 02:02 AM   #2
jcx is offline jcx  United States
even though onboard cards can suck big time they are likely adequate for loudspeaker testing as long as you have appropriate gain for the mic
the highest price performance in soundcards is likely the ESI Juli@ which I bought for ~ US$130
have you checked your internal soundcard with (free) RMAA in loopback mode?
http://audio.rightmark.org/index_new.shtml
Old 11th August 2007, 05:25 AM   #3
dangus is offline dangus  Canada
Just about any sound card will be good enough for speaker testing, providing it is good at full-duplex (playing and recording simultaneously). The SB/Ensoniq AudioPCI was supposed to be pretty good for a budget card.
An SB Audigy 2 should cost well under $100, and if the Rightmark results can be believed it's capable of very good performance.
Old 11th August 2007, 09:18 AM   #4
Pjotr's Avatar
The old Soundblaster Live is still around for under $20,- and will do this job pretty good provided you stick to 48 kHz sample rate only. You need a good mic amp anyway.
For a high quality card you can also look at the M-Audio Audiophile 2496 and the Audiophile 192.
Cheers
Old 12th August 2007, 09:23 AM   #5
well, I went to Rightmark and read about pro.
What is that telling me?
Is it good for me/my computer?
why does one need to do that?
How does one do that?
regards Andrew T.
Old 12th August 2007, 01:16 PM   #6
Ron E is offline Ron E  United States
Ron E's Avatar
If your computer is newer than 5 or 6 years, the on board chip is probably good enough. Really old AC97 chips work fine.
Creative makes junk. Pursue alternatives. I bought a Chaintec AV710 and it works quite well for SW. Blows the old SBLive away for half the money.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 13th August 2007, 12:00 AM   #7
you can down load a free version of RMAA from the Rightmark site
loopback testing simply require wiring soundcard out to in and running the RMAA test, many soundcards have been tested this way - its practically the standard
http://www.pcavtech.com/soundcards/compare/index.htm
Old 13th August 2007, 12:21 AM   #8
Brett's Avatar
That page is over 3 years old.
Try an M Audio 24/96 or 24/192 (which is what I use).
Old 13th August 2007, 12:32 AM   #9
Geek's Avatar
Sometimes you can find the odd older Yamaha DS-XG cards that slipped into the "junk bin" at computer shops by error (they still command $$$, but look like an ordinary 16-bit C-Media card if you don't look closely). 48KHz sample rate default (duplex, 96KHz simplex) and -110 to -120dB noisefloor.
Sound Card Based Audio Test &amp; Measurement System, 21-day fully functional Free Trial! VIRTINS Vendor's Bazaar 43 29th July 2011 03:10 PM
Loudspeaker Quality Measurement dm1179 Multi-Way 1 14th June 2007 07:57 AM
Attenuator for sound card measurement AR2 Parts 8 9th January 2006 10:13 PM
MLS measurement with Speaker Workshop and Creative USB sound card: not working tcpip Multi-Way 35 22nd August 2005 03:22 AM
Page generated in 0.09733 seconds (81.03% PHP - 18.97% MySQL) with 10 queries
