| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#1 | |
That thread is closed, but encouraging people whose knowledge and construction skills are virtually unknown to build tube amps with 800 volt power supplies is just fine? Or recommending people fix their hum problems by using cheater plugs? How are the dangers involved in the construction and operation of something like this necessarily any worse than the dangers involved in the construction of anything with an AC power supply in it by someone who doesn't quite know what they're doing? I mean hell, a 300 watt amplifier swings 75 volts at its speaker terminals, which is more than enough to kill someone. se |
#2 |
Steve, it is our policy, as you well know. If you don't like it, you don't have to post on diyAudio. We don't force you to keep coming back.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
If the thread in question was intended "as a learning experience" it was actually irresponsible to close it. We missed the chance to learn why "directly connected transformerless amps are dangerous in construction and operation".
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
The answer is simple:
If the plug is inserted into the wall outlet the wrong way around or the mains wiring is wrong - the one who touches the amp will be nuked !! This will not happen to the constructor usually but most often to his spouse, children etc .... This should be reason enough for not attempting it. Regards Charles |
#5 | |
Not that diyAudio hasn't the right, just want to be clear on the sentiment. se |
#6 |
Peter, as you know, it was a rule in place when we both became moderators a good few years ago. If you, or anyone else wants to discuss our policy, there is the excellent Moderating thread you opened a while back that is for just that purpose, so please post any further comments there.
#7 | ||
se |
#8 |
Hi Steve, The use of directly connected power supplies without an isolation transformer is extremely dangerous. This is well accepted by just about every government in the world. We learned because of it's widespread use earlier in time. The problem with talking about it is that young constructors normally have a very flip attitude about safety. They figure it was done before to save money, so they can do it now and save money. The same holds true of some of our less responsible members. So, rightfully, we have a solid rule that spells out that we delete a post or close threads that deal with this practice. This is a stance that I completely agree with and support. I'd rather that people not even consider this as an option. This is not open to discussion. -Chris Edit: I decided to lock this thread. Enough has been said already. Do not open another thread to continue this topic.
"Just because you can, doesn't mean you should" © my Wife |
#9 | |
se |
#10 |
Steve, I see this slipped by. End of discussion! It's not about freedom to post, it's about being responsible about safety. I will delete further posts past this one. -Chris
| Safe Transformerless Amps Possible? | Trout | Tubes / Valves | 7 | 17th August 2007 01:55 PM |
| transformerless amps? | zenmasterbrian | Power Supplies | 107 | 16th September 2006 10:48 AM |
| Active cross-over, solid state amps connect directly to tweeter? | Drew Eckhardt | Multi-Way | 14 | 24th August 2003 06:36 AM |
| Transformerless Amp - Possible? | lgreen | Solid State | 7 | 27th June 2003 10:57 PM |
| Page generated in 0.11207 seconds (82.91% PHP - 17.09% MySQL) with 10 queries |
