| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
XLR has 3 conductors. and the 3 wires/connectors are usually +/- signal and ground.
I was thinking of something like: + = right channel - = left ground = ground instead of 2 male-terminated RCA cables going from preamp to poweramp, I only have one. good idea? or bad idea? |
#2 |
Crosstalk will kill your channel seperation. |
#3 |
bad.......
#4 |
and I had such high hopes for it!
![]() thank you very much |
#5 |
You need to use one cable per cannel and ground one wire at one side.
Houston, we have a problem! |
#6 |
wouldn't there be any crosstalk on an xlr cable? or maybe there's none because the +/- signals cancels this?
#7 |
Did it Himself
Once wired for 2 channels the balanced feature is lost, so there is not +/- cancelling.
There will not be a big crosstalk issue if good cable is used and the length is not too long. Remember Naim use almost the same scheme. It has the advantage of preventing ground differences between channels. My only change to your proposal would be to use the + as left and the - as right. It just follows convention better that way.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#8 | |
I was unclear and I apologise for that. I meant crosstalk on a xlr cable used as an xlr cable (1 channel per cable and not left/right channels on the same cable). |
#9 |
what if one used two twisted pairs feeding the stereo XLR? One pair for left and one pair for right. The ground connection meeting in the plug and taken into the audio ground attached to the socket. How would crosstalk measure with this arrangement? Would this increase or decrease the propensity for hum?
regards Andrew T. |
#10 |
Did it Himself
Both crosstalk and hum would be reduced
However, the propensity to get ground voltage differences would be similar (but a bit better) to using normal phono connections.
| New in package Component Video Cable and Toslink Cable for sale cheap | jainbaby | Swap Meet | 1 | 30th December 2007 05:18 PM |
| Unbalanced cable "directionality"... mismatched instructions?!?! | lgo51 | Pass Labs | 18 | 30th April 2005 04:51 PM |
| Question about Audioquest cable CV-4 connection | Alex2 | Multi-Way | 0 | 24th March 2005 10:15 AM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| Page generated in 0.10785 seconds (78.34% PHP - 21.66% MySQL) with 10 queries |
