Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th January 2003, 08:21 PM   #1
Question need help with DCF-77 time signal detection
Does anyone know a good method to receive the dcf-77 time signal, not using a complete chip but made up up with different components (like opamps, filters (LC), mixer (IC)...
We're working on a dcf-project at school and I was thinking to receive the signal with ferrit core antenne in parallel with a cap (matched on 77.5khz). I was told that I've got to bring down the frequency with a (balanced) mixer (otherwise the Q-factor of the filter must be extremely high). Can I use a second 77.5 khz signal (on the other mixerinput), so that there will be a DC-component and the double freq. Can I detect the information (= kind of AM pulses) out of this DC-signal (after LPF) or not?
The detected signal will be decoded by own written software...
Any comments or other ideas welcome!
Is it also possible to make a kind of low pass filter with an opamp based on the Gain Bandwidth Product (=constant). So the higher the Gain the lower the bandwith will be (so better selectivity).
Thanks in advance!!
HB.
Old 3rd May 2003, 04:27 PM   #2
Thumbs up BY THE WAY PROBLEM SOLVED
we just started to build and simply worked it out
jack detection signal? Heimhenge Digital Line Level 10 8th February 2009 11:46 PM
AMP CLASS A to B detection fab Solid State 41 9th August 2008 07:45 PM
EAC Drive Detection Problem hajame Digital Source 7 23rd February 2008 06:40 PM
Dc-detection, is this correct? fixation Solid State 12 16th February 2006 07:08 PM
Page generated in 0.06770 seconds (68.61% PHP - 31.39% MySQL) with 11 queries
